Radix + Nitrous..outcome?
Old Jul 22, 2009 | 07:59 PM
  #21
skyhighsami's Avatar
no title here
I would think you would need a full tube head because because usually the primaries on the shorties are 1 5/8. I am sure you will need a 1 3/4 for the flow you have. The JBA headers and MAC headers I have had used a 1 5/8 primary
Old Jul 22, 2009 | 08:29 PM
  #22
trever1t's Avatar
2nd fastest 5.3 ECSB
the factory Y is also a little restrictive imo. If you just want to cool things a little go with a meth kit. I use the AlkyContol kit without issues. It won't cool things too much but the meth will add a little margin of safety.
Old Jul 22, 2009 | 09:18 PM
  #23
brobradh77's Avatar
Originally Posted by trever1t
I have run 35/50/and 75 shots thru my Radix with no noticible drop in IAT's. I have not heard of any of the other users on these boards ever report any IAT differences but you will make gobs more power without increasing IAT's if that counts. Spraying methanol didn't really drop IAT's all that much eaither
Originally Posted by cccharged
Ha..so basically there is no way to drp IAT's then?..i only want to do a small shot(35)..what kinda diff would thins make in power and torque?
I run a 75 shot with my maggie and see no IAT differences....What I did was get with Rick from Trick turbos and he built me a cooler box that I can fill with ice water...I just got it installed and am getting ready to test it out...If it works well I may make it a chiller box where he taps your a/c...keeep the water temps at 60* or so
Old Jul 23, 2009 | 07:19 AM
  #24
cccharged's Avatar
Well post up the results..sounds like a nice setup.
Old Jul 23, 2009 | 08:07 AM
  #25
krambo's Avatar
Originally Posted by skyhighsami
Nah, ZEX I think makes a kit on the end where on a cone filter it says KN that they put a nozzle. They spray across the MAF and let it richen the intake.
Yea, that is the basics of a dry shot using the MAF. Here is what mine looks like:
Couldn't have said it better myself. I am tuning a 6.0L SS with the radix and a 75 shot. He picked up a bunch of MPH and ET however had zero improvement in the IAT department (measured anyway) with any sized jet. The truck's kit is the same as the one I posted above.
Old Jul 23, 2009 | 08:13 AM
  #26
trever1t's Avatar
Hey! that looks a lot like my setup, except mine injects into the tube ~4" before the TB.
Old Jul 23, 2009 | 10:22 AM
  #27
zippy's Avatar
The one thing to keep in mind with a Radix truck and spraying a dry shot is whether or not you have enough maf range. If you are anywhere near close to maxing the maf and you spray through it you will be running a risk of running it lean if you run on the same tune for nitrous as without the nitrous.
Old Jul 23, 2009 | 10:45 AM
  #28
no title here
Isn't there a coating on the rotors of the Magnachargers that meth or n2o will damage or was that an internet rumor
Old Jul 23, 2009 | 10:53 AM
  #29
marlboroman71818's Avatar
Nitrous oxide is more dense and has a boiling point of -129F and will boil as soon as it is injected. Physics says that it will cool the intake charge vs ambiant air. Maybe its because you guys run a radix and inject it before the compressor or after the IAT sensor is why you do not see any drop in IAT's?
Old Jul 23, 2009 | 11:07 AM
  #30
trever1t's Avatar
it's allowing an increase in cylinder charge without increase in temps, plus the shots are relatively small and running through a compressor/intercooler.
