radix newbe
Old Nov 25, 2006 | 08:17 PM
Bill Reid's Avatar
Depending on how many miles the 6.0 block has... let alone... possibility of oil starvation (I ASSume) I would recommend getting the cylinders checked. You may need to eBay the Mahles if more than a cleanup hone is performed.
For bearings I recommend the Clevite H series for the rods and Federal Mogul for the mains. If you are having the block checked by a machinest let HIM tell you if the cam bearings are good/bad. As far as cam bearings go... don't let looks deceive you. Again though... if oil starvation is suspect it may be best to yank the cam bearings and start over... in that case Durabond makes a nice cam bearing.
I also recommend the rotating assembly be balanced... (since you are local) if you don't have a machinest I recommend Basko Engine Service.. ask for Ray.
... and most definitely pin the crank...
Chad at AZ Power and Sound will take care of your tuning needs assuming you stay local...
Bill
Old Nov 25, 2006 | 08:24 PM
Originally Posted by Diablo666
never herad of that but i'll do some reserch on that thanks
Magnacharger does a pinning kit that is standard on their Corvette kit.It's easy to install if you have a lift.Look at the Corvette instructions page on the Magnacharger web site.
Old Nov 25, 2006 | 08:41 PM
Diablo666's Avatar
Bill
i had the engine for a couple of months cylinder walls are fine and yes i have the the clevite's and the federals' too i was tinking basco engines too
bagged7104SS
Sep 24, 2015 08:42 PM
lxcoupe
Aug 24, 2015 08:16 PM
JFortner5
Aug 20, 2015 06:13 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
