Radix N20 Question
If mine would hook it, I'm confident it has 1.5 60's in it. A full 75 out of the hole is the limits of traction. Front end lifts and it hops rather violently. Thats the only reason I got the progressive controller.
I am getting ready to install my NX nitrous kit. It will be on a progressive controller. I am currently running about 8.5# with a 2.9 pulley on the 6.0.
My question is, should I...
Run a 75 shot with 8.5#?
Run a 100 shot with 6.5#? (3.1 pulley)
I am leaning towards less boost and more nitrous because the engine will not have to overcome the pumping losses of the blower and suffer from IAT issues.
yeah, I posted up mine back in late September? They definitely made a big difference in my launch. No lifting, no torque steer, just straight out of the hole.....and yes, I agree with Trick's statement, as I have been telling you Jason.
Missed your thread. Found it and saved the pictures. The ones I remember were posted up by Ty.
You probably will not feel the 75 shot especailly with a progressive conroller. Anytime working with nitrous you should start small and work your way up. But with a blower; you will probably not be happy at 6.5# while not on nitrous. So I would set it up with the 8.5# and bring the nitrous in. Depending on which progressive you got you maybe able to set up mild or wild on the ramps with only a flip of the switch. and be rpm or time based.
I know, I know. I just need to do it already.
carid
Sep 10, 2015 09:07 AM
