radix with meth kits
Old Nov 1, 2005 | 10:36 PM
TurboGibbs's Avatar
Originally Posted by dewmanshu
got the hpt...$ugh...got the EIO...$ugh...got the SD upgrade...$ugh...should of went ahead with the 2 bar. Jeeesh...hey wait a minute why didn't anybody tell me how expensive this **** is!?!?!??! LOL
I don't have my alocohol yet (finally hooked up but no juice yet, might just run some windowwasher fluid for now-haven't read much opinion on that topic on here), but I'll have my before and afters on the iat's next week hopefully. Mine is setup up for rpm (3500) and boost of 2psi. I don't remember my jet size. I'll make a note of it though. I really want the progressive, but didn't get it then...my bad, but I am so done ponying up more money. If anything thing maybe up the boost mark to 4psi, just as mjhoward says...it goes to pe so damn quick...hell it's there already, no need to be progressive.
You've got a 3.0 pulley on a 6.0 correct? How about the 3.0 on a 4.8? It is almost impossible to accelerate and keep it pulling vacume! The bad thing is I want to try the 2.75 but I won't go there until I get the 2 bar map.
Old Nov 1, 2005 | 11:55 PM
thunder550's Avatar
High on diesel fumes
196 before, 160 after running 50/50 water and meth. This was on a WOT freeway run from 75 to 130+ both times, on the same tune both times. I have the alkycontrol kit with whatever nozzle came with it. 3.0 pulley on a 5.3 pushing 9 psi.
Originally Posted by moregrip
the meth will take the coating off the Radix rotor set, don't know what that means to ya, and I'm almost sure you already knew that, just figured I'd through that in the mix
How bad is that? I didn't know it would do that.
Old Nov 2, 2005 | 06:56 AM
dewmanshu's Avatar
Moderately Differentiated
Oh I could only imagine...I've been SD tuning and I thought about you 4.8 guys. I can just keep it out of boost enough to get some reliable #'s, I imagine those smaller cubes fill up real quick on you...hence the 12psi you got there.
I do plan on a 40/60 mix as dc96819 noted.
Old Nov 2, 2005 | 08:44 AM
bud8fan's Avatar
yes that 40/60 meth/distilled water looks like it does the trick as far as cooling the best...
Silveradorst07
Dec 31, 2015 12:04 AM
greedygenius
Sep 3, 2015 06:51 AM
WICK3DxGATA
Aug 31, 2015 07:21 AM
tim wellington
Jul 31, 2015 03:28 PM
Deceptarado
Jul 8, 2015 05:24 PM
