Radix installed, What pulley size???
Old Apr 3, 2007 | 10:55 AM
FastCrewCab4x4's Avatar
Default Radix installed, What pulley size???
Have everything installed, Boost Gauge shows 4.5psi WOT. Mods are in sig. whats the best size pulley to make more boost without having to spray meth or other cooling enhancers.
Old Apr 3, 2007 | 09:15 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Drop .2 from whatever size you have now. I'm guessing you have a 3.4", try a 3.2"
Old Apr 3, 2007 | 09:21 PM
dewmanshu's Avatar
Moderately Differentiated
man...only 4.5 pounds. I thought the stock kit will give ya 6psi at least. You are a 6.0L but interesting.
Old Apr 3, 2007 | 09:25 PM
1SlowHoe's Avatar
Well if he a bought a 5.3 kit (used etc..) plus he has headers, he could only see 4-5psi. I think he needs a 3.2 with the 6L to make 6psi, maybe even a 3.0 if his exhaust is flowing well.
Dyno it, power is what you are after, not a boost number.
Old Apr 3, 2007 | 09:28 PM
cyazo6's Avatar
I am running a 3.0 on my 5.3L.
Old Apr 3, 2007 | 09:29 PM
dewmanshu's Avatar
oh i know, boost is just a measurement of resistance...i didn't mean to make it sound like he should be high in the boost #. I just would of thunk even with headers, big exhaust he would made a little more than 4.5#'s.
Old Apr 3, 2007 | 09:35 PM
dewmanshu's Avatar
LOL...want a cookie? LOL
Sorry... I am high on painkillers, that was funny to me for a sec.
Okay, what kind of boost are ya seeing? But the thread starter is a 6.0 so he has more cubes to fill.
Old Apr 4, 2007 | 06:15 AM
It is a new kit, Whats the difference in a 5.3 kit, to a 6.0 kit? Wouldn't more psi make more power?
Old Apr 4, 2007 | 06:51 AM
dewmanshu's Avatar
nothing..no difference between kits besides tunes.
Yes more psi makes more power. But a restrictive exhaust also raises boost (resistance), so by putting on a smaller exhaust is a case where getting larger boost wouldn't work for ya. Actually once the blower is installed and you have established a baseline for boost readings, I'd be brave enough to speculate that any mod you did that made your boost drop would net you more power.
Dropping pulley size will increase boost and power if the tune is changed as well. It's not good to change pulley's w/o making changes to a tune as well IMO.
Old Apr 4, 2007 | 06:37 PM
Stoichiometric's Avatar
The Radix kit on my 6.0L makes 6 lbs with the stock 3.2 pulley. I have all the supporting mods plus a GT-7 cam, fwiw.
