Radix is installed, only one problem...
Old Nov 4, 2005 | 07:47 PM
Holty's Avatar
Notorious BIG
Default Radix is installed, only one problem...
Got the Radix installed today, only took about 7hrs with ALOT of help from a great group of friends, including our own Bill Simpson (wkdivr) from the forums here. Install went very smooth the truck runs great!
Only problem i'm having is i'm getting a CEL. We hooked up a code reader and the code its putting out is a P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency. We checked, and double checked all the connections for the MAF and the IAT censor. Called Magnuson, but didn't really get much help from them. They said it was a incorrect/bad connection to the IAT sensor, but i'm sure its not, as we checked and double check. They also said let it go for a couple of days and it "might" go away? Just thought i'd post here to see if anyone can help. Thanks.
Old Nov 4, 2005 | 07:48 PM
Holty's Avatar
Notorious BIG
Also want to note, we cleared the CEL and it came back shortly after.
Old Nov 4, 2005 | 08:04 PM
dewmanshu's Avatar
Moderately Differentiated
Change your sig! I hate to admit it...I had that code in the beginning...uhm...it did go away. It didn't happen right after install, but it did come about a week later.
Old Nov 4, 2005 | 10:43 PM
Holty's Avatar
Notorious BIG
so what did you do? how did you fix it or are you still driving around with a CEL?
Old Nov 5, 2005 | 09:23 AM
therock's Avatar
Default New K&N?
Try cleaning the MAF?
Old Nov 5, 2005 | 12:56 PM
dewmanshu's Avatar
That was about it...I sprayed it down with electrical cleaner and it never came back.
Old Nov 7, 2005 | 03:50 PM
wkdivr's Avatar
ttttttt
Old Nov 7, 2005 | 03:58 PM
Holty's Avatar
Notorious BIG
UPDATE:
still getting the CEL. Hooked up a friends HPTuners to my truck and deleted the code. It came right back though. Decided to do some logging and i sent the log file off to Bryan at pcmforless to see what he has to say. Waiting to hear back from him...
Old Nov 7, 2005 | 04:03 PM
moregrip's Avatar
what a rush!
UPDATE:
If your using the stock Radix tune I would send Magnuson your tune if you think there is a problem with it, they can fix it if need be
Old Nov 7, 2005 | 04:24 PM
Holty's Avatar
Notorious BIG
yes, i'm still using the stock Radix tune. though, when i called there tech support, the kid i talked to never mentioned sending it to them or anything. he basically said it mmight go away, it might not. wait and see. but, i'm tired of waiting, it's been 3 days, but i'll try to call them back again though.
