Radix install questions???
Old May 19, 2010 | 07:46 PM
Iggyg00's Avatar
Default Radix install questions???
OK, so i bought a used radix and have a couple of questions for the install that dont seem to be covered in the manual.
1. The radix has a west coast cyl. head 90mm j tube, the unit is off of a dbw truck and i am putting it on a dbc truck.
The question is with the dbc where do i get the bracket that bolts to the jtube to hold the cables? Is this something from magnacharger? Also do i need a gasket for the tb to jtube connection, as there looks to be a green o ring already around the opening( j tube side)?
2. For the intake to head gasket:
The manual for the 2003-2004 shows 8 seperate seals while the 2002 manual shows the factory plastic seals. I think that the one i have has the 8 seperate seals.
Question:
Do I need new seals or are these reusable?
Do I need to use the factory seals?
Thank you in advance
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
therock
Jul 25, 2015 09:23 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
