Radix Guys...What fitting for boost & fuel pressure
Old Dec 11, 2005 | 01:09 PM
BLASTER's Avatar
Default Radix Guys...What fitting for boost & fuel pressure
Hey guys,
I got the blowere on order and the guages but I am tying to figure out the fittings I need. I don't have the blower in front of me so I don't know what ports is how so can you guys help.
Thanks
Old Dec 11, 2005 | 05:12 PM
thunder550's Avatar
High on diesel fumes
What guages?
Old Dec 11, 2005 | 07:26 PM
1SlowHoe's Avatar
Destroyer of Transmissions
The fuel pressure gauge is gonna have an electric sending unit that taps into the fuel rail where the schrader valve is right now. It's a 1/8" thread. Your gauge should have directions for install. Plus a 12v and ground for the light and a power wire for the sending unit if I remember right. The boost gauge is mechanical and will only need 12v and a ground to light up. The gauge will read off the vacuum line on the radix, just insert a "T" inline and plug in the hose from the boost gauge. You'll understand when you see it all in front of you.
Old Dec 11, 2005 | 11:29 PM
BLASTER's Avatar
Vac/Boost and Fuel Pressure...in title...
More specifically the C2 electric series. My boost will be electrical sender.
Just worried about the plumbing, not the electrical hook-up.
Old Dec 12, 2005 | 01:08 AM
thunder550's Avatar
Oops didn't see that. 1SlowHoe got it right on, I did it the same way.
Old Dec 12, 2005 | 11:13 PM
BLASTER's Avatar
Does the fuel pressure sender need anything else to tap into the schrader valve, like a T or something?
My boost guage is electric. What size T will I need for the vaccuum line? I've heard to use a 1/8 NTP to barb???
Old Dec 12, 2005 | 11:30 PM
1SlowHoe's Avatar
You can screw the fuel pressure sender directly into the schrader valve. You will not be able to bleed off fuel rail pressure anymore unless you unscrew the sender. You could go to a hardware store and get a 1/8" "T" and put the "T" into the rail and hook up the schrader to one and the sender to the other. Depends how creative you want to be. The boost gauge should read from the vacuum lines on the radix. they are all 1/8" so a 1/8" "T" will fit right in and hook up to the gauge. Unless an electric gauge reads from a PCM signal in which case I have no idea.
Old Dec 26, 2005 | 04:40 PM
BLASTER's Avatar
Where are the vaccum lines on the Radix? Thanks.
So I will need a 1/8 hose barb "T" for the boost?
Old Dec 26, 2005 | 05:05 PM
1SlowHoe's Avatar
Yes a 1/8th" T. Here are some pics of mine. You can see the metal "T" in there.
Old Dec 26, 2005 | 05:13 PM
BLASTER's Avatar
Can't see the image.
