Radix Fuel Injectors
Originally Posted by zippy
If you go to the SVO injectors you'll have enough fuel for all the air a 112 blower can push.
I assume the Magnacharger fuel pump will keep up??? Wouldn't be surprised if you all said no........
Jim
Tin Foil Hat Wearin' Fool
The fuel pump will be fine, go with the motron 60#ers and you will have to swap your factory truck style injectors plugs for car style, so add another 40 to get them from Allen. There isnt really anything between the 42s and 60s. I think the SVOs may be rated at 42#s at 43psi or something like that if so they would be a middle of the road option. Allen has the injectors and plugs, I wouldnt complain too much about going to bigger injectors, it could be worse, I had to go the 1200 buck route for a versafueler and injectors along with going to a dual intank pump.
Allen just e-mailed me. He said I need to use 60#'s.
So which 60 # injectors? Motron or SVO?
I need a different fuel injecor harness now too?
I still didn't get a comment on the fuel pump being fine or not.
Jim
Jim
GXPJAY
02-13-2022 08:15 AM
