Radix Fuel Injectors
Old Dec 3, 2006 | 04:01 PM
Question
Originally Posted by zippy
If you go to the SVO injectors you'll have enough fuel for all the air a 112 blower can push.
What size SVO injectors and where to buy cheap?
I assume the Magnacharger fuel pump will keep up??? Wouldn't be surprised if you all said no........
Jim
Old Dec 3, 2006 | 04:57 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The fuel pump will be fine, go with the motron 60#ers and you will have to swap your factory truck style injectors plugs for car style, so add another 40 to get them from Allen. There isnt really anything between the 42s and 60s. I think the SVOs may be rated at 42#s at 43psi or something like that if so they would be a middle of the road option. Allen has the injectors and plugs, I wouldnt complain too much about going to bigger injectors, it could be worse, I had to go the 1200 buck route for a versafueler and injectors along with going to a dual intank pump.
Old Dec 3, 2006 | 05:48 PM
Scott Mills's Avatar
The SVO's or Delphi 42's will flow around 48lbs at 58psi. The truck style injectors that come with the Radix only flow 42lbs at 58psi.
Old Dec 4, 2006 | 12:14 AM
Question
Allen just e-mailed me. He said I need to use 60#'s.
So which 60 # injectors? Motron or SVO?
I need a different fuel injecor harness now too?
I still didn't get a comment on the fuel pump being fine or not.
Jim
Old Dec 4, 2006 | 07:13 AM
krambo's Avatar
At 500RWHP I am at 105 IDC with 50/50 meth using the 42# injectors at over 60psi on the FP. I have the SVO's sitting on the workbench. Just lazy.
GXPJAY
Feb 13, 2022 08:15 AM
adunphy
Feb 22, 2016 06:38 PM
RONIN LSX
Aug 11, 2015 12:03 AM
jrplz
Jul 9, 2015 12:07 AM
