Radix comparable to?
Old Mar 30, 2007 | 08:16 AM
firefighter's Avatar
Default Radix comparable to?
I had read here some time ago someone comparing the Radix or maybe just a regular 112 to either a B&M or Weiand roots type blower as far as efficiency and performance does anyone know? I would appreciate it.
Old Mar 30, 2007 | 09:02 AM
BlownChevy's Avatar
blownerator
25 Year Member
There is absolutely no comparison that can be made with the above mentioned superchargers. The Radix/112 is a 5th gen hybrid roots that has taken the efficiency of a roots blower beyond what any of the other roots blowers could imagine. With the twisted rotors and APC the Radix runs very tight tolerances that allow it to operate at speeds and conditions that would have destroyed early style roots blowers. Trying to compare it to a 3 or two lobe roots would be like trying to compare a 75 year old woman to an 18 year old virgin (woman).
Old Mar 30, 2007 | 09:27 AM
nice comparason.......
Well here is the goal I guess what I need is to find out it's specs and I dont understand the charts.
I need to know the following if you could help it would be fantastic.
1 island flow/cfm
2 rotor speed/rpm
3 peak efficiency/%
4 surge flow/cfm
5 belt ratio
6 boost limit/psi
7 pressure ratio
8 internal ratio
9 intercooler efficiency/%
What I'm trying to do is get some accurate specs for my Dyno Sym program. I'm just trying to get some idea of the potential for a "possible" project of putting one of these on the 4.3L I like the idea, I just want to get a rough idea of what it'll be worth. If you can help me I would greatly appreciate it. Also I realize some of those specs may apply only to turbos if so lemme know because I'm new to the S/C deal I've built a number of motors they were just all N/A.
Thanks in advance for any help you can give.
Old Mar 30, 2007 | 09:30 AM
BlownChevy's Avatar
blownerator
25 Year Member
1 island flow/cfm
2 rotor speed/rpm
3 peak efficiency/%
4 surge flow/cfm
5 belt ratio
6 boost limit/psi
7 pressure ratio
8 internal ratio
alot of that info is not available from EATON, however moregrip has complied alot of it through horse trading with people in the industry and is using the SAME sofware as you. I am sure he will post up.
Old Mar 30, 2007 | 09:38 AM
Thanks Brian I appreciate the responses hopefully Grippy will post up too.
Old Mar 31, 2007 | 06:53 AM
TTT, if anybody has some info it will help me tremendously. Thanks
Old Apr 1, 2007 | 06:51 PM
Can anyone help me with this info? Please?
Old Apr 1, 2007 | 07:04 PM
moregrip's Avatar
what a rush!
yes, I'll get you some info later tonight
Old Apr 1, 2007 | 09:03 PM
perfect I appreciate it man. Thank you.
Chavette
Oct 28, 2015 07:33 PM
Mark_k
Oct 1, 2015 11:17 PM
bagged7104SS
Sep 24, 2015 08:42 PM
97_ek
Sep 23, 2015 09:16 PM
jroctpb
Sep 16, 2015 09:05 PM
