Radix+cam idle question
Old Jul 18, 2007 | 09:23 PM
Holty's Avatar
Notorious BIG
Default Radix+cam idle question
You guys with semi-lopey cams and a Radix what rpm are you idling at?
Old Jul 19, 2007 | 07:27 AM
krambo's Avatar
I don't consider mine lopey however I idle at a "high" 950. If I don't idle that high, I get that torsional isolator knock from the snout.
Old Jul 19, 2007 | 07:32 AM
Holty's Avatar
Notorious BIG
See i have a similar problem but not with the blower snout. Its from my belt tensioner smacking off its stop. Other than that my truck idles fine at 650rpm. I wonder if i could adjust my idlers or move to a longer belt would help?
Old Jul 19, 2007 | 05:16 PM
doublenot's Avatar
I had the same belt tensioner knock. mine idle fine at 650 I wasn't sure what could be done. I was thinking maybe a shorter belt so the tensioner wouldn't move as much.
Old Jul 20, 2007 | 07:22 AM
Holty's Avatar
Notorious BIG
You say you "had" the same problem but no longer do? A shorter belt will only make the problem worse as it will make the tensioner ride even closer to its stop, which is bad for many reasons. Mainly because hard on/off throttle transaction will likely snap the tensioner from the abrupt stop of hitting the stop.
Old Jul 20, 2007 | 11:47 AM
doublenot's Avatar
Yeah I no longer have that problem as I pulled the blower off and I'm going to trade my truck in on a nnbs. That is the reason I never switched to a shorter belt, seems like fuelslut was breaking belt tensioners daily so I just dealt with it.
Old Jul 20, 2007 | 11:55 AM
dewmanshu's Avatar
Moderately Differentiated
that'll solve the problem.
Just do what i said hotly, turn your RTT for idling on and increase that idle 25 to 50 rpm at a time until it gets to where you are happy with the chatter and see how that is. I bet it's not as high as you'd think.
Old Jul 20, 2007 | 12:06 PM
Holty's Avatar
Notorious BIG
Mossyoakglock
Aug 28, 2015 12:49 PM
smokeshow
Aug 23, 2015 08:23 PM
05GMC4.8
Aug 7, 2015 09:55 PM
USMCvet0311
Aug 1, 2015 07:45 AM
fillpot
Jul 26, 2015 07:21 PM
