A/R swap...
Old Aug 7, 2008 | 10:22 AM
Stoichiometric's Avatar
Originally Posted by Spoolin
...yes you are right, that is true! However, since it's back here anyways... I thought I'd see what I can make of it before moving it up front which is where it will end up eventually.
The good thing is once you have the housing swapped you will be ready for turbo relocation surgery if your other fixes don't help enough.
Old Aug 8, 2008 | 01:05 AM
Spoolin's Avatar
GFYS and STFU
I think I'm gonna do the cam first actually. But in any case it isn't gonna happen till I get back from my next deployment which looks to be January. I'll be coming up next weekend with some smaller gears and see how she does at the track. You still coming right henry?
Old Aug 8, 2008 | 01:06 AM
Spoolin's Avatar
GFYS and STFU
I'm leaning towards 3.42's instead of 3.23's...any advice/preferences or recommendations?? I'm swapping them out on Tuesday.
Old Aug 8, 2008 | 06:59 AM
thunderwagen's Avatar
Originally Posted by thunder550
Should be pretty easy to do. Disconnect oil feed and drain (and coolant lines if it's water cooled), disconnect air filter from turbo inlet, charge pipe from outlet, any vacuum lines run to the compressor housing, remove bolts or v-band clamp from turbine outlet, remove 4 bolts from turbine inlet flange and you got yourself an uninstalled turbo. The there should be probably 8 bolts or so holding on a ring or something that keeps the turbine housing attached. Remove those, and the housing should slide right off.
What Thunder said and then move the turbo forward about 4 1/2 to 5 feet and reuse the metal gasket with a little orange rtv or the copper crap. Then you wont have any problem with that .96 spoolin!
Old Aug 8, 2008 | 07:01 AM
What size tires are you running and are you running a 60E or an 80E?
I had 3.73's with my 60 and they were fine, but when I went to the 80E I had a big flat spot coming out of the hole, especially since my street tires are 32" tall. I went to 4.10's and it fixed that.
Old Aug 8, 2008 | 07:57 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
go the 3.42's you'll get great milage on the way here and won't feel so bad about leaving with your tail between your legs
Old Aug 8, 2008 | 09:05 AM
Wilde Racing's Avatar
How do I change this text
LMAO... wow
Old Aug 8, 2008 | 02:57 PM
Spoolin's Avatar
GFYS and STFU
I have a 80E and running 32" tall tires. My truck came with 3.23's + 60E and I actually liked that combo but was convinced to swap in 4.10's. But with this combo I'm not loading up the engine/turbo enough in 1st and 2nd gear to see full boost, and blow through the gears way too fast.
I figure if I make my gearing a little shorter I can get better gas mileage, load up the turbo better in lower gears, and consequently stay in my power band a lot longer as well.
Well...
How bout a friendly wager then Bill? I'm not ready to break into 11's yet since my current set up still requires some tweaks to it...but how bout trap speed? Whoever gets the higher trap speed buys dinner afterwards, or if your really confident in the harpoon...loser pays to top off the winner's fuel tank afterwards!
hmmmm....what do you say big boy??
Old Aug 8, 2008 | 06:22 PM
WJ MARK's Avatar
Make sure he tops you off with 104, lol!!!!
kha4079
Oct 29, 2018 04:38 PM
kush killer
Feb 17, 2016 09:20 PM
GMCtrk
Oct 20, 2015 06:17 AM
08lambochevy
Aug 7, 2015 11:42 PM
iregret
Jul 27, 2015 10:32 PM
