Quick Spool Valve
Old Jan 20, 2011 | 01:40 PM
DoubleTrouble's Avatar
Default Quick Spool Valve
Would a quick spool valve be necessary on a Lq4 with a S480 turbo for my daily driven truck?
Are quick spool valves all what they're hyped up to be?
Old Jan 20, 2011 | 01:50 PM
smokeshow's Avatar
Mod with training wheels
The 5.3 would probably never spool my turbo without it...so yes, they certainly do work as advertised. With the stock converter I'm at full boost by about 75 feet. Should spool much quicker with a better converter.
Old Jan 20, 2011 | 01:56 PM
OnyxSilveradoSS's Avatar
I would say its more about converter...If you have a 3k stall, the few RPM's you get from the spool valve will help. If its your stock converter then it might not make a differance.
Old Jan 20, 2011 | 02:17 PM
3200 Yank here..
Old Jan 20, 2011 | 03:03 PM
2toneblown's Avatar
wow....
Old Jan 20, 2011 | 05:42 PM
blue0453's Avatar
Im running a mpt76 with a yank 3200, boost comes in very quick.
Old Jan 20, 2011 | 05:53 PM
smokeshow's Avatar
I've got a 3000 Yank coming. I'll post up how the QSV/new converter combo spools the S400.
Old Jan 20, 2011 | 08:44 PM
brent1976's Avatar
11 Second Club
Can someone post a link, so I know what you are talking about.
Old Jan 20, 2011 | 08:47 PM
brent1976's Avatar
11 Second Club
Nevermind, I found it but don't understand how it works without choking the exhaust off to much.
Old Jan 20, 2011 | 11:00 PM
smokeshow's Avatar
The valve opens as boost increases, so it regains full exhaust flow after the turbo spools up. The supra guys who run them leave the valve closed until they reach their target boost, and a hobbs switch triggers the valve to open up. I just run it straight off the manifold with no hobbs switch, though. Cracking pressure is 4-5psi, full open is about 9.
