question regarding magna charger 6.2L
Old Sep 21, 2008 | 08:45 AM
fairline's Avatar
Default question regarding magna charger 6.2L
I had sts turbo befor in my old truck ,
i was satisfied with the sound of the turbo only , i faced problem with tuning alot .
my question is , does magna charger for 6.2l new L92 engines comes with tune ? is that tune is accurate and will work out ?
i travel alot with my truck , can i do 100mph all the time while am traviling without problem with the s/c at boost levels?
thanks in advance i need these answers cos your answers will let me decide to buy the magna or no
Old Sep 21, 2008 | 10:26 AM
BlownChevy's Avatar
blownerator
25 Year Member
as long as the engine is in vacuum you will not be in boost. If you are going 100MPH up hill you might have a problem.
Old Sep 21, 2008 | 11:41 AM
TG02Z71's Avatar
Either you live in Montana or on a race track!! 100mph all day? LOL
Too funny. If that's possible more power to ya!!
I wouldn't think that would be too good for your vehicle in general but with boost you could have issues like BC said up hills or under load.
Be carefull.
Old Sep 21, 2008 | 11:43 AM
fairline's Avatar
thanks for the update.
first of all am only planning for 5 psi only since this is my daily use car and completely stock .
iam not talking that am doing 100mph at vacuum boost .
lets say am doing 100mph at 3psi boost .
and does the kit include a tune ?
Old Sep 21, 2008 | 12:25 PM
1BADAZZSS's Avatar
Be carefull.
I dont think he lives in the states....
Old Sep 21, 2008 | 12:39 PM
BlownChevy's Avatar
blownerator
25 Year Member
We are developing the tune for the 6.2L Denali right now....Thanks to a generous board member
Old Sep 21, 2008 | 05:06 PM
dubai911's Avatar
what do you mean when you say it's not safe to drive 100mph with a SC?!!! this is my average speed
even on say slight uphill/load.. what kind of problems should I expect?
Old Sep 21, 2008 | 05:17 PM
nonnieselman's Avatar
IATs will start rising...
Old Sep 21, 2008 | 05:33 PM
BlownChevy's Avatar
blownerator
25 Year Member
I am not saying it is not safe...and I am not saying you will have issues. I am saying if you are going 100MPH and getting under enough load to drop below 8 inches of vacuum you will be in boost.
IAT will NOT be an issue.
Old Sep 21, 2008 | 05:40 PM
XLR8NSS's Avatar
Adkoonerstrator
With my TVS1900 kit my IATs actually drop when going into boost from cruising.
If my cruising IATs are 50 C they go down to around 43 C under boost. Put it in C since more than likely that is the temp scale he uses.
The only way I can explain this is that when the bypass closes under boost you are no longer circulating air through the compressor. If I stay in it a LONG time I have seen the temp rise like 2 degrees C. That was on a run to 120mph which takes me a little bit to get too.
I'll try to get a screen capture of one of my logs to post up.
