Question for fellow ProCharged Chevy guys...
Old May 24, 2006 | 01:22 PM
Superado's Avatar
11 Second Truck Club
No one has addressed this yet?
I thought that I would bring this around to the top again because I want to figure out why my power steering squeels when turning left only.
I know, I know, just make right turns!
Old May 24, 2006 | 03:33 PM
Black Blown 02's Avatar
I took my blower off after 7,000 miles and checked the ps fluid level, it was perfect, so I figured unless something goes wrong, it'll be fine.
Old May 24, 2006 | 03:47 PM
Superado's Avatar
Well, I just rolled over 180K miles. Not to jinx my truck, but, I wanted to look at my options prior to any failures or problems.
Old May 26, 2006 | 12:43 PM
SCIV's Avatar
With the engine cold I was able to get it out. Took a lot of patience, but it did come out. Now I don't know how accurate it is since I had to tilt it to get it out.
Old Jul 24, 2006 | 04:07 PM
Superado's Avatar
Well, I finally checked it...never been changed...never been checked after the ProCharger install...you definite have to wait until the area is cool, but it really isn't that hard to get to and out, however, I would suggest cleaning all areas surronding the cap really well before removing it because crap will fall in then and when replacing it and you can't clean when the cap is off for the same reason.
The fluid level was fine...however, after 184k miles on the same PS fluid, I chose to change it while I had the dipstick out. I used the syringe that I use to change out my ProCharger oil with and sucked out all of the old PS fluid, replacing it with the expensive *** Lucas product. The Lucas product is way too thick for the syringe so I just aimed and squeezed...all was good until that thickness of that stuff being forced out the small hole in the spout forced the cap right off the bottle. Luckily I was almost finished so I didn't have that much of a mess. So, cut the majority of the spout off when opening if you plan on using this stuff.
The squeeling that I have always had to some degree when turning to the left...GONE!
Old Jul 24, 2006 | 04:29 PM
As far as changing the procharger oil, I made a long steel braided tube that screws into where the drain plug is, with a plug on the bottom I can just drain the oil from the bottom of my truck. Now I have to service the head unit with 7oz of oil, but it is alot easier and less messy!
Old Jul 24, 2006 | 09:23 PM
BrianGallimore's Avatar
The braided tube is a good idea.
Did you guys bother to move your positive battery "jump start" connection? I am eventually going to go back and mount it in the left wheel well, so I can get to it without popping the hood.
D1SCSS
Jan 25, 2016 10:14 PM
Stainless Works
13
Nov 5, 2015 03:31 PM
USMCvet0311
Aug 1, 2015 07:45 AM
hackrst
Jul 11, 2015 11:17 AM
