question about tapping oil pan
Drill and tapping is fine. I pulled my pan on 07 and the were some stuff at the bottom from the factory. My 00 we drilled and tapped go slow use lots of greese pull the tap out several times walking the tap in to the proper depth. Each time wiping the greese off the tap and from inside the pan. Regreese and repeate.
Rick
From: Where our street cars are faster than your racecars..Mississippi
if you do it in the while the pan is still on the truck.... at least drain the oil afterwards then re fill it before you start it.. so hopefully you have all the little metal shavings flushed out
I did it with the pan off the second time, the thought of aluminum shavings in my new forged motor wasn't appetizing. I drilled a hole and used a -10 bulkhead fitting (locknut on the inside) with locktite and a little sealer around the hole. No leaks yet. The first time, I did it in the truck (stock motor) just use lots of grease, drill it and tap it as straight as possible, and change the oil/filter afterwards.
