question about tapping oil pan
Old Oct 17, 2009 | 06:52 PM
GMCtrk's Avatar
I've asked this before and the response was just to change the oil afterwards.
Old Oct 17, 2009 | 07:23 PM
TrickTurbo's Avatar
Truck Sponsor
Drill and tapping is fine. I pulled my pan on 07 and the were some stuff at the bottom from the factory. My 00 we drilled and tapped go slow use lots of greese pull the tap out several times walking the tap in to the proper depth. Each time wiping the greese off the tap and from inside the pan. Regreese and repeate.
Old Oct 17, 2009 | 08:28 PM
Rick_Vor's Avatar
Originally Posted by LsxCody
Thanks for the help guys. Rick did you say you had the motor in the truck when you drilled and tapped it
Yeah, I did it with the pan attached, engine in the truck. I'd do it again in a heartbeat. I had to do it twice and it was still a piece of cake. Just take your time and keep cleaning the bit and tap.
Rick
Old Oct 17, 2009 | 10:41 PM
LsxCody's Avatar
Thanks man. I'm gonna tap the front of my pan too
Old Oct 18, 2009 | 12:08 AM
2004SSS's Avatar
exactly how i did it , take your time . if you try and rush , just think of how much more time it will take to pull the motor.
Old Oct 18, 2009 | 01:10 AM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
if you do it in the while the pan is still on the truck.... at least drain the oil afterwards then re fill it before you start it.. so hopefully you have all the little metal shavings flushed out
Old Oct 18, 2009 | 02:22 PM
silver-mod-o's Avatar
Hunt&Fisherator
I did it with the pan off the second time, the thought of aluminum shavings in my new forged motor wasn't appetizing. I drilled a hole and used a -10 bulkhead fitting (locknut on the inside) with locktite and a little sealer around the hole. No leaks yet. The first time, I did it in the truck (stock motor) just use lots of grease, drill it and tap it as straight as possible, and change the oil/filter afterwards.
Old Oct 18, 2009 | 02:33 PM
LsxCody's Avatar
Thanks for all the help guys
spent21
Aug 19, 2015 02:37 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Ls3silverado
Jul 31, 2015 04:22 PM
05SilveradoSS
Jul 29, 2015 08:34 PM
jmarkway
Jul 18, 2015 09:23 PM
