Pushed coolant on LQ4
Old Nov 12, 2011 | 03:08 PM
sharpshooter's Avatar
Default Pushed coolant on LQ4
I'm seeing very small amount coolant dripping down block between 5 & 7,never seen before but truck has not been run in 2 weeks. Not sure if l'm noticing it because it has been sitting so long and not evaportating off block. I think I'm running to much timing for the amount of boost - no kr on logs. The heads have never been off/still running TTY's.
Could this go away if I back down the timing or are the bolts stretched and need replacing? Guessing the latter!
If they need to come off is this what I need for repair?
studs or bolts
ls9 gasket or just stick with lq4 gaskets - if going ls9 does it change the comp.?
Clean heads and block and put back together.
Old Nov 12, 2011 | 03:27 PM
bud8fan's Avatar
i would not panic...run it and see if it stops...prolly will.
Old Nov 12, 2011 | 03:32 PM
SincalT/A's Avatar
I think you could delay inevitable failure but,do you really wanna risk another motor being hydrolocked.What year lq4 is it?Btw.My 4.8l leaked in the same spot when I lifted a head.
Old Nov 12, 2011 | 03:51 PM
SincalT/A's Avatar
Douh! Was it sureshot that hydrolocked his procharged lq4 idk one of yous guys did.Jus play it safe keep driving to minumum till you get a chance to fix it.I agree bring the timing back a few degrees.
Old Nov 12, 2011 | 04:01 PM
SincalT/A- It's a 2006, it was me that hydrolocked my last lq4 with meth/water.
Old Nov 12, 2011 | 05:03 PM
02'Z71ONDUBZ''s Avatar
If you think you might have lifted a head I would go ahead and order LS9 gaskets and ARP studs and fix it before any real damage happens. Time to make those ported 317's a reality
Old Nov 12, 2011 | 06:00 PM
Due the ls9 gaskets change the comp.?
Old Nov 12, 2011 | 06:55 PM
TIM Z's Avatar
11 sec. Truck Mod
Sorry To Read this Russ, but im sure with just a little work you'll get it fixed.
I would use stock LQ4 gaskets.
There are 2 different gaskets for the LQ4 depending on year as i was told from SDPC, the 03 and earlier IIRC is different gasket from the later 03/04 LQ4's just so ya know.
When i got my 6.0 last year i put new stock gaskets and headbolts on since i changed the lifters before i installed it. No problems so far and i love to smash the go pedal!
Old Nov 12, 2011 | 10:05 PM
denali_on_26's's Avatar
From: Where our street cars are faster than your racecars..Mississippi
yes ls9 gaskets change your CR... IIRC they are .071 but even GM rely on them for a boosted application..
Old Nov 13, 2011 | 05:04 AM
What would the comp. be on my lq4 with the ls9 gaskets?
