Pulley and belt sizing
Old May 23, 2016 | 02:09 PM
MikeD.'s Avatar
Default Pulley and belt sizing
I'm dropping down from 4.25 to a 4.00 pulley on my d1, and just wondering if I just need a belt that's a 1/4" shorter then what I have now to have the same tension I do now?
Old May 23, 2016 | 02:15 PM
Atomic's Avatar
I have a gauge for that
Its not so much about tension, but tensioner travel remaining. As long as the tensioner can take up the slack on the other side then you should be ok.
But for the record, you would need closer to 1/2" shorter to keep it the same.
3.14159*(4.25-4)*0.5 (lets assume the belt has 180 degrees of wrap) = 0.39"
Old May 23, 2016 | 03:22 PM
MikeD.'s Avatar
Ahh ok, I figured it wasn't that easy. As of right now my tensioner is beyond maxed out, but has worked so far
Old May 24, 2016 | 12:45 AM
RedLS's Avatar
How many pounds were you at with the 4.25, I'm curious to know how much a 4.00 will increase boost. 2-3lbs???
Old May 24, 2016 | 12:50 AM
RedLS's Avatar
You can use a string and run it around the system and get your measurement that way also. Just make sure your tensioner is comperssed.
Old May 24, 2016 | 11:01 AM
MikeD.'s Avatar
They say roughly 1lbs per .10 of an inch. So I would assume 2-2.5lbs. I'm currently peaking 7-7.5lbs on the 4.25.
Old May 24, 2016 | 11:09 AM
madmann26's Avatar
There you go with that gradeschool math again. Pie, everyone likes pie.
Old May 24, 2016 | 02:20 PM
MikeD.'s Avatar
That's gradeschool?? I guess I should have stayed in school..
Darknight-4
Mar 8, 2018 09:24 PM
BLOWN 364
Jan 20, 2018 09:22 PM
flatblack83
May 19, 2016 03:41 PM
rednekferlife101
May 6, 2016 02:21 AM
Lowexpo
Apr 28, 2016 11:19 AM
