Pulled the LSX yesterday......
Old Oct 6, 2010 | 10:09 PM
  #51
DrX's Avatar
DrX
No cab on an Av.
A few more pics of # 8:
Old Oct 6, 2010 | 10:18 PM
  #52
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Its still held onto the frame just like the rest of the GMT800 platform trucks. Not saying its going to be easy but if its that close you may have to install the blower that way. Dont forget to disconnect the steering shaft, everything else has enough slack in it to allow 2" of lift.
How the hell do you even lift that monstrosity you call an intake manifold?
Old Oct 6, 2010 | 10:24 PM
  #53
DrX's Avatar
DrX
What?..... it's only 150 lbs.
j/k.......same way I drop the engine in.
Old Oct 6, 2010 | 10:26 PM
  #54
1Bear's Avatar
It’s hard to tell from the picture, but pleas tell me that’s not a crack in the cylinder towards the right side of the picture. Maybe just a piece of string or something lying in there.
Old Oct 6, 2010 | 10:57 PM
  #55
DrX's Avatar
DrX
Just lint from wiping the oil off the cylinder wall.
Old Oct 6, 2010 | 11:00 PM
  #56
53RUSSELL's Avatar
I feel your pain i'm going through same thing but pulled motor before that happen.
Old Oct 6, 2010 | 11:02 PM
  #57
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by DrX
Would have been a lot closer to where I needed it!
Duttweiler has been doing this for a while, with great results.
Old Oct 6, 2010 | 11:23 PM
  #58
1Bear's Avatar
Whew! I hoping so, it's already bad enough without worse news.
Old Oct 6, 2010 | 11:28 PM
  #59
DrX's Avatar
DrX
LOL...I got halfway through posting "are you seeing good results with this?" before I was interupted this afternoon. Good to know.
Old Oct 7, 2010 | 12:08 AM
  #60
2004SSS's Avatar
might have to move mine there as well.
do the ls2 style knock sensors use the same wiring ? could we just splice them into the gen3 to 4 conversion harness? or do the electronics work differenty? seems like it might be better to try a knock sensor that was designed to work in that spot vs the ls1 style .
