Pulled the LSX yesterday......
Old Oct 6, 2010 | 08:40 AM
  #41
DrX's Avatar
DrX
Originally Posted by matthew20061
That sucks to see hope you can get it fixed and running again...
Got 6 months til the track re-opens.
Old Oct 6, 2010 | 08:46 AM
  #42
TrickTurbo's Avatar
Truck Sponsor
Damm long winters up there.
Old Oct 6, 2010 | 11:17 AM
  #43
Doobie's Avatar
Hockey and Racing.... sounds just fine to me "A".
(I couldn't resist, my bad)
Old Oct 6, 2010 | 11:23 AM
  #44
DrX's Avatar
DrX
.....Eh?
Old Oct 6, 2010 | 11:43 AM
  #45
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Do you think it could be a flow issue with your custom manifold?
Old Oct 6, 2010 | 01:07 PM
  #46
DrX's Avatar
DrX
Lower intake is just an open box, much like the new Magnacharger and Harrop designs. I think that the boost would fill all the cylinders evenly, but not certain that there were no intake to head leaks, which could screw everything up.
Old Oct 6, 2010 | 02:04 PM
  #47
Doobie's Avatar
I concur with your intake leak having caused the problem. This will wreak havoc on the best of intentions. Did your gaskets show any sign if pinching, tears, misalignment or uneven compression?
Old Oct 6, 2010 | 03:38 PM
  #48
DrX's Avatar
DrX
Uneven compression. It would be very easy to chew up the gaskets though while trying to shoehorn the fully assembled setup onto the engine. Its a very tight squeeze getting it under the cowl.
Old Oct 6, 2010 | 05:34 PM
  #49
TURBHOE's Avatar
so next time take the cab off. install SC's onto the motor then set the cab back down on the frame.
Old Oct 6, 2010 | 07:59 PM
  #50
1slow01Z71's Avatar
Many of the diesel guys have to lift the cab to get the diamond eye downpipes on, all they do is loosen all the cab bolts till they barely engage the threads in the body/core support and use two floor jacks to lift the cab 2ish inches. Makes all the difference in the world
