Propane Turbo 5.3 first track day video
#23
Great runs John!!!
Glad to see you get it going so well!
It's comments like these I will never understand....
You guys realizes there is a 26 gallon PLASTIC tank of HIGHLY flammable liquid gasoline mounted under your truck with nothing but 2 straps???? Only thing between it and the pavement is a thin metal shield...
I guess out of sight, out of mind???...
#24
Willing to bet GM put a lot of effort into making sure that plastic tank is very safe...more effort than your typical joe is going to put into safety considerations when bolting a huge propane tank to the bed. In that form the pressurized tank of propane is much more dangerous than a plastic tank of gasoline.
No one ever plans on wrecking, especially with something like this, and I hope it never happens, but if he does, it will be very bad if that tank is ruptured.
#25
MASS seller approved
Thanks, the small A/R makes it fun to drive, I am sure its a bit restrictive but I tried to find the balance and had no idea if it would even work when I spec'd it out. If anyone has a cheap used or new Tnetics F1-68 .96 ar housing laying around I would love to test it out it.
The mixer and vaporizer are basically regular propane parts, the carb hat didnt need to be billet, it just saved me the time to fab one up that would do the job. The billet lid is just insurance against boost leakage at the regulator.
Cost difference to doing up a gasoline jobbie would be minimal, It's probably somewhere between a thousand more or hundreds less depending what kind of builds you are trying to compare and how thrifty you are. You can spend a boat load on gasoline fuel system parts in a hurry. For instance my uni-bomber tank was $200 on craigslist and was half full
The biggest cost comes in the form of time learning how to figure it all out and tune it...
#26
Its a thick steel tank designed to be bolted into the back of a pick-up truck, bolted into the back of a pick-up truck... Now my sled, that was a different story
Thank you Kyle, it has come a long way!
#28
I dont want you to take my comment the wrong way, I think your project is great. You didnt give any details about the tank setup so I assumed the worst, but since it is purpose-made for what you are using it for, then I dont forsee a problem with it (not that you need my approval anyway
). Just wanted to clarify that.
#29
Funny, they said the same thing about gasoline back in the day.
Driving period is dangerous these days.
I see atleast one wreck every morning and hear of no less than 2 every morning.
We are rigging up a similar setup on my buddys trail buggy with a 22RE. Once we get it figured out, its gettin a turbo.
You are tuning it with the stock PCM correct?
#30
Great runs John!!!
