Progress made on HD tensioner...
Old Apr 23, 2012 | 09:23 PM
BigKID's Avatar
Looks great! In for final results.
Old Apr 24, 2012 | 07:47 PM
Superado's Avatar
11 Second Truck Club
installed.
Old Apr 24, 2012 | 08:49 PM
Beatdown Z's Avatar
Laid Back
Nice work!
Old Apr 24, 2012 | 11:09 PM
Superado's Avatar
Originally Posted by Beatdown Z
Nice work!
Thanks!
Gotta pick-up a longer bolt tomorrow to mount tensioner to bracket.
Friend that made the bracket went ahead and put several indexing pin holes around the mounting pad of the bracket to increase it's adjustability.
Will post a pic tomorrow.
Old Apr 25, 2012 | 10:58 AM
kbracing96's Avatar
That's indexed differently from how mine did...
But I guess that's why you put all the indexing hole in it
Old Apr 25, 2012 | 05:37 PM
Superado's Avatar
Yeah, I was busy @ a job-site all day yesterday and was keeping in touch thru text as they were mounting it. The clocking of it was the FIRST thing I asked about when he sent me that pic. He said it needed to be @ 11 o'clock. Is that pic from the ProCharger set-up you had briefly?
I'm gonna stop by and look at it tomorrow...didn't get a chance to today.
Old Apr 25, 2012 | 07:05 PM
kbracing96's Avatar
Actually it was a Kenne Bell, but yes. That was the 8 rib setup I ran.
Old Apr 25, 2012 | 07:31 PM
Superado's Avatar
I made it by the shop tonight before they left and took a look at it. It definitely needs to be clocked @ +/-1:00 w/o belt which should place it it @ +/- 3:00 w/ belt.
Index pin hole @ 6:00 should do this. The reason it was @ 11:00 in the photo was to allow them to use the laser alignment tool and be able to hit the idler and crank pulleys with it.
Old Apr 26, 2012 | 03:52 PM
Superado's Avatar
kb, BigKID and schino...
That's about the same index pin hole location you guys ended up with as well, correct?
Old Apr 26, 2012 | 04:53 PM
schino's Avatar
yeah mine sits at about 2:30 or so with the belt on. i put the pin hole in a place so that if it were up against the stop the belt would be close to the point of rubbing on the hub of the tensioner. if you have it too verticle with no belt when the belt stretches it will rub
