Progress made on HD tensioner...
Started off with a Gates 38518 tensioner from Rock Auto:
http://i172.photobucket.com/albums/w...ates_38518.jpg See pg2 for tensioner specs: http://www.goodyearep.com/uploadedFi...ifications.pdf Then with the info shared here by BigKID and schino and some tweaking of a drawing by the Design Engineer at my office, I have a friend working on machining a bracket for it. The CNC went down right after he got started so he ended up having to make it manually. He said the back would've had smoother transitions if done on the CNC, but I'm very happy with the results. He's rounding off the corners on another CNC later today. Front: http://i172.photobucket.com/albums/w...cket_front.jpg Back: http://i172.photobucket.com/albums/w...acket_back.jpg Test fitting tomorrow...noting any clearance concerns we may have... also marking the location for the indexing pin hole. :thumb: |
I would add a couple of extra indexing holes at 20 degrees either side of what you think you'll need. This way you can adjust where the tensioner bottoms out if need be. You don't want the belt slamming the tensioner at the ends of its travel when you get hard on the gas or let off.
Looks great!
looking good!
Looks good. Wish I had access to a CNC machine. Not sure what I would use it for but im sure I could find something LOL
Originally Posted by swift700
(Post 4909530)
Looks great!
Originally Posted by schino
(Post 4909537)
looking good!
Originally Posted by ak2007r6
(Post 4909538)
Update tomorrow! :) |
Tell him to make a few more, you qualify to sell in the member made section ;)
Update:
One of the steps on the back hit the water pump so a little milling tonight and she should be good to go! :D |
(Post 4909584)
