proflo xt and new intake/cold side for the old turbo kit...
Old Oct 31, 2012 | 04:16 PM
  #31
TURBHOE's Avatar
It may be the same size boat most people don't have a long run after the gate. If you can with out burning anything I would say unhook the gate from its dp and run it open and see if it still does it. Just one quick run. If it doesn't then you know you need a bigger pipe on it. You have to concider that your gate needs to exhaust anything the turbo doesn't need. And at bigger power it will need to flow more. Just like the exhaust of your turbo. My run is not that long but I used a 2" pipe vise a 1.5" pipe. After I did this I lost a pound of boost. Unless I hit the switch.
Old Nov 1, 2012 | 07:50 PM
  #32
t_thall's Avatar
if you look at the first pic you can see the wastegate placement, it is right before the turbo after the two hot sides merge. There is a sharp 90 right after the wastegate so thats probably restricting it as well
Old Nov 2, 2012 | 03:09 AM
  #33
Denali08's Avatar
Your coolant tank is stock but relocated, right? How did you secure it there? and would it fit there with A/C? I can see that you don't have A/C.
Old Nov 5, 2012 | 09:45 PM
  #34
t_thall's Avatar
i just built a steel bracket to relocate the stock coolant tank. I do have a/c, i just had to bend a few lines a bit
chopperloco
Jul 10, 2016 10:45 PM
08lambochevy
Aug 7, 2015 11:42 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Blackrat48
Jul 12, 2015 07:28 PM
