the procharger thread
Old May 18, 2012 | 04:20 PM
  #51
Pc2000trk's Avatar
No intercooler adds a couple , stock heads adds a couple then your cam can make a difference + exhaust setups
Ati told me a long time ago that new cam 2-3lb loss , heads 2-3lb loss , long tube full exhaust 1-2lbs so it's possible but we're talking about a 408 with stage 3 317's at 6k with belt slip ..
Old May 18, 2012 | 10:14 PM
  #52
idahoblkss's Avatar
Thats why it doesnt make sence that he made the same boost as me with the same pulley when he is a 408/heads...etc. something isnt adding up. Calling bs at this point.
Old May 18, 2012 | 11:47 PM
  #53
Blown06's Avatar
8 Second Truck Club
I'm confused. What are calling bull **** on?
Old May 21, 2012 | 06:27 AM
  #54
blown02408's Avatar
02 w/ lowest mileage 2800
Originally Posted by idahoblkss
so how di d you make that much more boost , was it not having a intercooler that made the difference?
Yup, nearly 4 psi! 8" overdrive pulley on dedicated 8 rib, 3.4" blower pulley, bellmouth no filter, no intercooler. The 3.7" pulley actually seemed to work better on that setup with very little belt slip and made 17psi at 6,800rpm.
Old May 22, 2012 | 12:20 AM
  #55
Phantomx55's Avatar
Just bought a P-1SC off a fellow member
Anyone know what cam and torque converter would go good with it?
Old May 22, 2012 | 12:28 AM
  #56
idahoblkss's Avatar
bigger the tq converter the better...lol . i have a 3200 and wish i would have gone 4k stall speed.
Old Jun 19, 2012 | 05:24 AM
  #57
AndysC3's Avatar
so what I'm figuring is I will need about a 4.0 to a 4.1" blower pulley to reach about 10# at 6600 with my truck. Does that sound about right. What is the stock crank size?
Old Jun 19, 2012 | 07:27 PM
  #58
jrmchevyman's Avatar
I think the procharger would be the perfect setup for your truck. If you don't like it, I'll buy the procharger off of you lol.
Old Jun 19, 2012 | 08:59 PM
  #59
AndysC3's Avatar
Lol, yea. Not sure if I should run the smaller pulley and shift higher, or run a smaller pulley and shift earlier. Run 10@ either way. And I'm pretty sure ill be happy with the d1sc.
Old Jun 20, 2012 | 07:40 PM
  #60
5.3 GMC's Avatar
5.3 with 120k on it. P-1, 10 psi, shift at 6300. 3 blown up 60e trannys since. 80e stabbed last weekend with a 3600 circle d. New intercooler setup. Still workin on gettin everything back together so I can hit up the track!
