Procharger set up ?'s
I'm thinking of putting a D1SC [intercooled] on my 1999 5.3 at 8-9 psi of boost with a Westers tune for the charger.Are 44# injectors and a 255lph in tank fuel pump going to be enough for this set up?
Yes, I run the Delphi 43# factory style injectors on my Denali at 11lbs, tuned with HP Tuners. They are maxed out, but they are working great. If you plan to do any further mods, you might consider a set of 60# injectors.
I would go ahead and spend the money on the 60 pound injectors, unless you are one of the very few that will actually stop and perform no more performance mods, lol. The fuel pump will be fine and you can add a BAP down the road if needed. Westers does very good mail order tunes, I used him when I was runing the Whipple for a bit before I had the truck dyno tuned. I would reccomend getting the truck dyno tuned though as soon as you can. Better to be safe than sorry.
Originally Posted by sharpshooter
So I could actually get away with the stock pump?
