Procharger idler bearings
Old Jun 29, 2015 | 02:47 PM
DrX's Avatar
DrX
Default Procharger idler bearings
Anyone sourced an upgrade for these(Fafnir 203VV)? I believe the originals are only rated for something like 12000 RPM, but are spinning over 17000 RPM. I think their longevity is limited due to the fact that the grease spins out of them. I recall finding some higher RPM rated bearings in the past, but never found a source for them.
Old Jul 2, 2015 | 02:29 PM
DrX's Avatar
DrX
These look like they will work(6203ZZ): 2 Bearing 6203ZZ 17x40x12 Shielded Ball Bearings
Old Jul 13, 2015 | 08:41 PM
DrX's Avatar
DrX
Will see how they hold out:
Old Jul 14, 2015 | 06:54 AM
Gadgetized's Avatar
Any 6203 bearing will work(any local parts store should have plenty). The letters behind the 6203 just tell you what seals the side has, if any. For the price of them I would just run what you have until they start making noise.
6203-2RS Bearing 6203 Radial Si3N4 Ceramic Stainless ABEC-7
http://www.6203bearing.com/6203ZZ-Be...ess-ABEC-7.htm
http://www.bearings-china.com/sitema...c-bearings.htm
Old Jul 14, 2015 | 08:00 AM
DrX's Avatar
DrX
Looks like the ceramics are even higher speed rated.
Old Jul 20, 2015 | 09:40 AM
Calbo's Avatar
The last set I bought from ProCharger were noisy from the get go. They told me that is not possible and to send them back. Never did and they only lasted less than 2k miles.
I normally buy either Japanese or German bearings and switch out when needed. Have almost 60k on the system and have replaced the idler bearings probably four times.
As I write this, it doesn't sound very reliable. WTF
madmann26
Apr 29, 2020 09:17 AM
lukn4trbl355
Oct 21, 2015 11:19 PM
murderedSS
Sep 27, 2015 10:16 PM
sTNT971
Sep 26, 2015 04:22 PM
Justin87gn
Sep 10, 2015 12:06 PM
