procharger head unit rebuilt?
Old May 2, 2011 | 04:38 PM
chevytk's Avatar
Default procharger head unit rebuilt?
How would I know if my procharger unit needs a rebuilt? I didn't see it installed or know how it was running before. Just know that it has like 23-25k miles. And its a P1sc for a 5.3 silverado 99-02
Old May 2, 2011 | 05:07 PM
Mangled03gmc's Avatar
Baltimore Whore
Check for shaft play( It should have just a touch of play back and forth).. If it was maintained, I HIGHLY doubt it needs a rebuild.. Turn the pulley by hand, make sure it is free, does not bind while spinning.. Next fill it with oil, run it for a bit, then drain the oil into a coffee filter, check for metal or anything that looks like it shouldn't be there..
Old May 2, 2011 | 10:49 PM
chevytk's Avatar
I checked it and it has a very little touch of shaft play in and out as you said, is this normal?... also checked the pulley and it spinned freely... what exacty does bind mean sorry but new to this and know nothing lol... thanks mangled03gmc
Old May 2, 2011 | 10:55 PM
Baltimore Whore
Yes that sounds fine.. Bind as in it hangs up trying to turn it.. Again if it was maintained, never ran it out of oil, I would bet it is fine.. No true way to tell unless it is opened up, but I would roll with it..
Old May 2, 2011 | 11:09 PM
chevytk's Avatar
okay cool... thank you....Its my first time getting boosted. I was going to use a twin screw but going to use this one instead. Its my daily driver and going to use some 8.1 marine injectors that I already have and the stall I have is a 2400-2600 around there but haven't installed yet and a tune. How many lbs of boost is normal and safe for my truck? Its an 02 silverado 5.3, with longtube headers with 3in y pipe, trutrac with 373, spacer and riding 20inch wheels may change to 22inch...
Old May 2, 2011 | 11:18 PM
Baltimore Whore
The 22's are going to kill the performance of the truck.. I would opt to go with a 3k+. The blower would have liked that much better.. You can run 10psi forever and not have to worry. Just be sure the tune is a good one, not some hack doing it..
Old May 2, 2011 | 11:23 PM
chevytk's Avatar
hmmm I guess I should just stick to my 20s then... I appreciate so much your help, advice and guidance mangled03gmc.... I'm going to try this stall I have here.. Would I need to install a shift kit in my tranny as well or just with the stall would be fine?
Old May 2, 2011 | 11:27 PM
Baltimore Whore
Yes def add a shift kit to the trans, alot of guys go with a trans-go kit, also a trans cooler..
Old May 2, 2011 | 11:31 PM
chevytk's Avatar
sounds good... where can I get this cooler? What size will be good? Don't know if this helps, but I live in south south texas where its like 100 everyday lol...
Old May 2, 2011 | 11:35 PM
Baltimore Whore
http://cgi.ebay.com/ebaymotors/ws/eB...em=#vi-content
D1SCSS
Jan 25, 2016 10:14 PM
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
blownss27
Jul 20, 2015 08:59 AM
