Procharger Filter Setups (Post your pics!)
Old Sep 13, 2012 | 10:21 PM
ak2007r6's Avatar
Default Procharger Filter Setups (Post your pics!)
Was looking at my Procharger and the stock setup and got to thinking. I was wanting to find an air filter that I can bolt right to the back of the Procharger and skip the elbow bend all together. I am hoping to find a bigger and better flowing filter that also has a small rubber neck that I can drill a hole for the PCV hose to connect to. I would then have the bypass tube dump to atmosphere and put a small breather/filter to catch any oil on the end.
Has anyone done this? Really just looking for a suggestion for an air filter. Is K&N the way to go here or is there other company's worth looking into??
Looking at using this at the end of the bypass tube (not home but if I remember correctly that tube is 1.5"ID).
Airaid - Product Search
Suggestions for the air filter??
Thanks guys
Old Sep 13, 2012 | 10:35 PM
Mangled03gmc's Avatar
Baltimore Whore
This is what I have. Get comps on it alot.
Old Sep 13, 2012 | 10:39 PM
ak2007r6's Avatar
You sir were the first person I thought of. I knew you had a different setup but couldn't find a post with a pic or description. I almost just shot you a PM instead.
Who makes that air filter?
edit.
I see k&N. Have a part number or dimensions by chance?
Old Sep 13, 2012 | 10:52 PM
Baltimore Whore
Not off the top of my head, but it is used on marine set ups, google K&N 496 MPI in images, you should see it.
Old Sep 13, 2012 | 10:59 PM
ak2007r6's Avatar
Looks very similar to this one
Will have to take some measurements once back home and see how big of a filter I can fit. Looks like you just have a 90 right elbow right off the back of the procharger?
Old Sep 13, 2012 | 11:11 PM
Baltimore Whore
Yes I have a 90 that fits the procharger collar, then have a aluminum reducer to put in that, it reduces down to fit in the filter.
K&N Flame Arrestor for 496 :: Flame Arrestors :: Diamond Performance Parts
Old Sep 14, 2012 | 02:48 PM
idahoblkss's Avatar
this is what i got going...
Old Sep 14, 2012 | 02:52 PM
Baltimore Whore
I could see that getting destroyed using as a daily driver. I thought about that, but then thought again.
Old Sep 14, 2012 | 02:59 PM
ak2007r6's Avatar
^^I would consider that at the track where it's a controlled environment but not as a DD. It doesn't take much at all to destroy an engine and those could let a very small pebble or something through.
Old Sep 14, 2012 | 03:05 PM
idahoblkss's Avatar
lol yeah i wouldnt recommend dd it like this, but dam does it make a difference .
