Procharded SS cam
Old Apr 24, 2011 | 12:28 AM
KDavis04ss's Avatar
You still looking for a bracket?? Or did you redo the idlers?
Nah I still need a bracket. Been asking everyone but no one wants to split up there kit. and the guys that do have a bracket dont have the bolts and spacers to go with it.
Originally Posted by AndysC3
On prochargers website it stated the ideal cam spec was a exhaust duration about 10* higher than intake and .1 more lift than intake. I'll see if I can't find the link. I'm going to run the comp 224/230 on a 114 when I go procharged.
I think it's 10* higher on the exhaust side and .010" more lift on the exhaust. I may be wrong but I read that on prochargers site a while back. I like the 224/230 But Im worried that may be a little big in this truck with on a 3k converter. I cut 1.8 60's all day long with the 228r on motor so the 224/230 should suit me fine I just want a good all around Tq/top end cam.
Old Apr 24, 2011 | 09:42 AM
AndysC3's Avatar
here is the cam specs from prochargers web page
Originally Posted by Procharger
Cam:
Lobe separation: 112 to 116 degrees Split pattern: Exhaust duration and lift approximately 10 degrees and .010, respectively, greater than intake. Install cam straight up. Contact a cam manufacturer for lifts and durations that best suit your application.
Old Apr 25, 2011 | 10:53 AM
Bad_Apple's Avatar
well my cam was spec'ed for my 6.Ol and not my 370, but it is a 224/230 610lift on 114lsa. done by Ed Curtis at Flowtech
Old Apr 25, 2011 | 03:33 PM
KDavis04ss's Avatar
I like those specs also Im just curious if they would spec something like that for a extended cab AWD. Good bit more weight than your regular cab.
2500ZL1
Jan 25, 2016 06:30 AM
lawhitediamante
Aug 12, 2015 12:14 PM
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
