Problems causing headaches!
Old Sep 2, 2013 | 08:38 PM
  #31
scooter k's Avatar
Originally Posted by TrickPerformanceProducts
What manual controller did you go with?
Are you applying psi to the top port or
venting the bottom port?
It's a hallman that I've had lying around. I can't remember what ports they're on but I'm Teed into boost reference to the input on the boost controller and I believe then to the bottom port on the gate. Output on the controller to the top port on the gate. I know if I reverse the hoses on the gate it works backwards. Meaning..tightening the **** makes less boost. Does hose length make a difference? Trying to figure out if I have these issues cause of too much hose?
Old Sep 2, 2013 | 08:43 PM
  #32
TrickTurbo's Avatar
Truck Sponsor
So no controller just the gate connected to boost port.
Your good.
Add a controller all hell happens?
Old Sep 2, 2013 | 09:01 PM
  #33
scooter k's Avatar
Your good.
With nothing hooked to the gate it does 10psi. Both ports open!
Old Sep 2, 2013 | 09:29 PM
  #34
TrickTurbo's Avatar
Truck Sponsor
Ok.
So bottom port needs to stay open.
The controller needs to apply psi to the top port.
The manual controller input boost psi.
Out put to the top port.
Controller should be close.
The boost psi should be the same or close to the same.
Then slowly open the controller ( 1/2 - 1 full turn)
Does boost goes up?
Old Sep 4, 2013 | 11:49 AM
  #35
idahoblkss's Avatar
you got a forged 408 on e85 .... pin the gate shut and let it eat!
Old Sep 4, 2013 | 07:37 PM
  #36
scooter k's Avatar
Yes! LMAO
Old Sep 5, 2013 | 07:18 PM
  #37
idahoblkss's Avatar
What injectors you running?
Old Sep 6, 2013 | 06:09 PM
  #38
scooter k's Avatar
ID2000's
I know someone that sells them cheapest around.
Old Sep 11, 2013 | 09:31 PM
  #39
idahoblkss's Avatar
So I was looking at the eboost 2 gauge instructions and apparently there are a couple of different ways of hooking the silinoid up to the waste gate depending on how much boost your running and if you have a hi back presure or what not. They also mention in the set up instructions it can only control as much boost as the waste gate can get rid of via spring or flow for that diameter gate. So it seems like it could be a number of things and might not just be the controller . Have you tried all 3 options on how they recommend setting it up? Just wanted to ask you since i'm preparing to set mine up here in the next couple days and started the reading on the manual to prepare as much as possible.
Old Sep 12, 2013 | 04:31 PM
  #40
carbongmc's Avatar
What MM gate are you running? Could be over flowing it and it cant keep up, or has it been working fine and this just started happening?
