Problems causing headaches!
Old Aug 24, 2013 | 02:09 PM
scooter k's Avatar
Default Problems causing headaches!
Went to the WS6 store open house today. On the way I laid into and it seemed like the transmission was slipping! Looked at the boost recall and it showed 28.9! 😩 Anyway I'm not sure if it actually pulled that or what??? Engine runs fine and transmission seems to act ok. Wondering if I hurt the engine any??
On the way back and almost home I tried it again and it was 23 psi. Then the truck died! Primary fuel pump died! I switched to the other and drove it home!
I'm trying to remember but I think those were 450 lph pumps. Does anyone make any pumps that like E85?
Old Aug 24, 2013 | 06:25 PM
Byrdman11's Avatar
You most like are ok. The 450 suppost to be ok with E85. I put a fuel pressure gauge that warns me if pressure drop to low.
Old Aug 24, 2013 | 09:23 PM
TIM Z's Avatar
11 sec. Truck Mod
Damn 29 psi , did you put a DURAMAX in that truck ? Lol
What caused the spike ?
Talk to Rob ( foose04) he just had a thread about dropping in new 450s for E85 .
In fact when I bought my 450 I thought it was rated for corn juice ? I'll have to double check , short term memory lol.
Old Aug 24, 2013 | 10:07 PM
scooter k's Avatar
Damn I don't know what caused the spike? Scares the **** out of me? It's always been something. A friend of mine has been through this and recommends turning the boost down to a reliable range.
Old Aug 25, 2013 | 12:19 PM
scooter k's Avatar
Pulled the tank out and the pump is definitely dead. Can't even bump start it with the hammer.....Is it a fluke thing or something else? I bought those pumps from Lonnie's Performance. He says they're custom made for him and won't tell me any other info. No markings on the pumps at all.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Aug 25, 2013 | 12:25 PM
mdwatts11's Avatar
I can't remember from your build thread, but are you running the FPCM or a return setup?
Old Aug 25, 2013 | 12:35 PM
scooter k's Avatar
return
Old Aug 25, 2013 | 12:48 PM
mdwatts11's Avatar
The 450s should work with e85 from my research. They should be reliable on a constant voltage setup to.
So just to confirm, you originally thought you had 450s, but now you think they are something from Lonnie?
Old Aug 25, 2013 | 12:54 PM
scooter k's Avatar
I thought they were 450's but after emailing Lonnie they are 340LPH.
Old Aug 25, 2013 | 03:16 PM
idahoblkss's Avatar
yeah get the new e85 freindly walbro 450's. i just got a pair and will be installing them this week. just make sure they are the e85 ones.
