Be a problem to mount a turbo to y pipe?
Old May 6, 2012 | 12:23 PM
sixt5's Avatar
Default Be a problem to mount a turbo to y pipe?
i dont want to loose my long tubes/y pipe from LPP, so would it be a problem to mount the turbo to the y pipe or close to it?
Old May 6, 2012 | 12:33 PM
Mangled03gmc's Avatar
Baltimore Whore
Nope it can be done that way. A turbo has no idea where it is LOL
Old May 6, 2012 | 12:36 PM
sixt5's Avatar
thanks for the quick reply!
that being said, im looking to start piecing things together. im looking for about 10psi as a DD, so what size turbo should i look for? going to be purchasing a used turbo to save money.
(i am serching btw, but there a tons of posts and im slowly reading through them)
Old May 6, 2012 | 12:40 PM
kbracing96's Avatar
You will have to use a pump to return the oil to the motor. FYI your headers will hurt you over stock manifolds and wrapped y-pipe. They dissipate to much heat and result in lower drive forces for the turbo.
Old May 6, 2012 | 12:45 PM
Baltimore Whore
I should have mentioned what KB said about the heat issue.Turbo's like heat, inturn spool faster. I would heat wrap your headers.
Old May 6, 2012 | 12:46 PM
sixt5's Avatar
i figured they would hurt me, im just trying to save some money. i could prolly ceramic coat them to keep the heat inside the header.
Old May 6, 2012 | 02:29 PM
02'Z71ONDUBZ''s Avatar
Here's a thought, sell them and pay for part of your turbo setup since they will benefit you in no way anymore. I don't understand how keeping them is a cost saving measure. Ceramic coating will allow the heat to dissipate faster and cost you more money.
zblee
63
Jun 10, 2023 01:25 PM
Wareagle23
Aug 8, 2015 10:06 AM
Jake99
Aug 8, 2015 07:56 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Mzay
Jul 6, 2015 11:03 PM
