Pro-Charger Lag
Old Jan 25, 2008 | 01:13 PM
Superado's Avatar
11 Second Truck Club
just installed FLT 4L60e Level 4 and Ulltimate Converter Concepts verter...
WOW...what a difference!
+1 on what everyone else said above...
Old Jan 25, 2008 | 01:38 PM
WJ MARK's Avatar
how big of stall did you go with? what did you have before? I think every procharger kit should come with a stall They just don't make any power down low till you put in a stall!
Old Jan 25, 2008 | 01:43 PM
Superado's Avatar
Lenny rated it as 2800...but said that it may stall as high as 3200
just got it in Wednesday night late...
hit yesterday a couple times...seemed to be more like 3000...
this was the first truck verter he's built...
he used a Northstar verter core...
Old Jan 25, 2008 | 01:50 PM
WJ MARK's Avatar
did you have a stock TC before. I know going from stock to a 3000 stall was HUGE. Totally different animal with the procharger!
Old Jan 25, 2008 | 01:52 PM
Superado's Avatar
had a TBTC for the last year or so...and it made a big difference at the track over stock...but this is like night and day...
Old Jan 25, 2008 | 02:09 PM
i have 3200 stall that flashes about 3400 and i think its killing me with my setup .... i am going to change it out to a 2800 tighter stall
Old Jan 25, 2008 | 03:31 PM
zippy's Avatar
The Prochargers do need a higher stall for better off idle performance, but not alot. A 2600-2800 stall is usually enough to get 60' times in the 1.7's without a problem. Most tuners just don't put enough timing down in the lower rpm's like they should when tuning a Procharged vehicle. None of that is related to the problem you're describing. If you have a lag in third it's likely from the converter locking in too soon as well as the COT not being turned off. make sure that your tuner isn't locking the converter until well past 5000rpm and that your COT protection is turned off.
Old Jan 25, 2008 | 03:36 PM
Superado's Avatar
didn't mean to hi-jack the thread...
thanks for getting us back on track Zippy...
as for the lag up top...I had big rpm drop on the 2-3 before...
this verter is way more efficient up top...
Old Jan 25, 2008 | 09:15 PM
Y2KLimited's Avatar
when the tahoe was a 350 and procharged the 2800 stall convertor and 4.10's (from 3.42s) woke it up a ton.
The subs setup doesn't complain with a stock converter though.....
Old Jan 25, 2008 | 10:18 PM
bpope's Avatar
Zippy, I think you are right about the timing being too low in lower RPM...I mean mine just doesn't rap out in 3rd like it did...it seemed to be almost bogging it. I think it would have made it a lot better though if the convertor wasn't locked up until later in 3rd.
The only bad part is...I won't be able to test any of this for a while as I smoked 2nd gear in my tranny.
Truck only has 25,000 miles on it. LOL.
madmann26
Apr 29, 2020 09:17 AM
LSXstef
Dec 22, 2015 08:31 PM
420
11
Aug 2, 2005 01:58 PM
LOTSOFN
Jul 30, 2003 01:54 PM
GREGGO
Jul 19, 2002 07:59 PM
