pressurized my coolant system ?
Old Apr 18, 2012 | 01:04 AM
idahoblkss's Avatar
Default pressurized my coolant system ?
last time at the track my last run i noticed when i got back to the pits that coolant sprayed out of my reservoir tube and onto my fender and that my radiator hose was pressurized like it was going to pop. got home and opened the overflow cap and it shot off and hit the hood and coolant went everywhere. i drove the truck home from the track and it wasnt overheating or any thing and i havent had a problem with it since. that last run i made the truck was cooled off pretty good to below 160*. i have a stock thermostat in it and will be putting a 160 in it soon. just wondering if anybody knows what might be going on or has had this problem b4.
Old Apr 18, 2012 | 01:46 AM
smokeshow's Avatar
Mod with training wheels
Moar power = moar heat = moar coolant pressure. Simple.
Old Apr 18, 2012 | 02:00 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I'd do a chemical "block test" to see if you have hydro-carbons in the cooling system. If it checks out okay, don't worry about a thing.
Old Apr 18, 2012 | 02:06 AM
smokeshow's Avatar
They don't make you run a coolant catcher for the overflow? And Roger, why is your name yellow? I must have missed something.
Old Apr 18, 2012 | 02:20 AM
I'm a sponsor now, supporting PT.net! Still a mod too.
Old Apr 18, 2012 | 02:23 AM
idahoblkss's Avatar
i was kinda thinking it was going to be either a sticky thermostat or a head gasket going. and no they dont make us run a catcher.
Old Apr 18, 2012 | 02:27 AM
smokeshow's Avatar
Hm, I thought that was NHRA regs...
Old Apr 18, 2012 | 10:05 AM
lt1s10's Avatar
If you really want to find the problem do a leak down test to make sure your gaskets are ok.
Old Apr 18, 2012 | 10:15 AM
TXsilverado's Avatar
wouldnt a leak down be easier? i dont know how a chemical block test works, but leak down is easy enough.
Old Apr 18, 2012 | 11:10 AM
Ferocity02's Avatar
Could this happen by lifting the head?
