Post your Timing and PSI
Old 06-25-2013, 07:53 AM
BigKID's Avatar
15#, 20* (pulls some timing in heat of summer via IAT table) with 11.2-11.5afr on 93oct E10.
Old 06-25-2013, 11:31 AM
franko98's Avatar
16 deg on 10 psi with meth lq4
Old 06-25-2013, 11:55 AM
travieso's Avatar
6 psi on 18*
Old 06-25-2013, 12:17 PM
I have a gauge for that
Atomic's Avatar
20psi 15-17deg with 2x14gph meth nozzles and pump 93.
Old 06-25-2013, 04:26 PM
black4.8's Avatar
16* timing on 16# boost w/ 93 and 26gph of 70/30 meth.
Old 06-25-2013, 04:33 PM
milkey57's Avatar
14# with 17* 93 + 100% meth
Old 06-25-2013, 05:10 PM
chevrolet all the way's Avatar
For anyone just running in here seeing numbers and adding timing to their setup keep in mind cam, heads, location, fuel, engine size, and many other things make up the correct timing for your engine.
with that said 9 psi 20° pulling timing over 115° iats. 93oct no meth. 12.0 afr
Old 06-25-2013, 05:11 PM
Also for you guys running low timing and rich to stay conservative need to know that you can very easily go too far and cause much worse damage than a properly tuned engine.
Old 06-25-2013, 07:45 PM
TRD_Tundra's Avatar
I wanna turn it up to 15psi and 15-17* timing but I'm not sure how long it'll last
Old 06-25-2013, 07:54 PM
I'm running 13 degrees and 13psi lucky numbers ehh? No meth and 93 octane
Quick Reply: Post your Timing and PSI
