Post your Timing and PSI
Old 06-25-2013, 08:23 PM
  #21
tiffo60's Avatar
Originally Posted by tim wellington
running 8lbs 18.deg 10.8 a/f . dont know if its right .starting to buck like a bull under load over 4000rpm i was going start a post like this morning .any of yall had this problem it may be in tune tried air flow meter and aero 340
Whats your spark plug gap?
On gasoline(up to E10) I would run atleast an 11.5afr, timing varies from setup to setup. I have seen same setup on two different vechicles not take the same amount of advance. One makes it best power 2-4* less than the other. Pretty close HP/TQ numbers on both. Why? Maybe someone with more experience than me can answer, I haven't learned enough to understand that part yet, lol.
Old 06-25-2013, 10:02 PM
  #22
foose04's Avatar
I running 14-15psi with 16.5 degree's in her. E85 and lots of rolling burnouts.
Old 06-25-2013, 10:04 PM
  #23
Resident Retard
BlackGMC's Avatar
i am running 8-9psi @ 16*.. I also have 2x7gph meth nozzle running 80/20 meth/water...
Old 06-25-2013, 10:11 PM
  #24
GMCtrk's Avatar
Instead of blanket timing numbers, anyone care to share how they ramp in their timing in regards to boost?
If using a custom operating system, at what boost level do you start pulling timing from the timing table?
I'd love to be able to rent out some dyno time and really fine tune alot of this stuff. It's alot to ask for on the street, especially when the rear tires are begging for mercy...
Old 06-25-2013, 10:25 PM
  #25
foose04's Avatar
Bring it in a little higher under the full boost curve area's and where you need power to get it up on the converter. Bring it down a hair thru peak TQ (5200) (peak cylinder pressure) and ramp it back in a hair up top once cylinder pressure starts to drop (6k+). This will keep the HP/TQ up on the top end and still keep pressure at or below where it was during peak tq.
Keep your AIT normal and my "normal" is below 130, don't beat on her hot "200+ eng coolant" with out taking some timing out on both accounts. Again this is on the safer side of the street for setting up timing.
Thats just how I go about it though.
Old 06-25-2013, 10:27 PM
  #26
Choda's Avatar
Stock 2009 5.3 engine
60lb inj
Trick stage 2 70mm
10psi
14* timing
10.9-11.0afr
Old 06-25-2013, 10:41 PM
  #27
GMCtrk's Avatar
Good post, and ironically, that's exactly how mine it setup....not really any different then when it was tuned n/a.
Unfortunately, trying to keep coolant temps and AIT down here in Texas currently is a bitch!
Old 06-26-2013, 10:43 AM
  #28
chevrolet all the way's Avatar
coming into boost my timing is like na basically. then starts dropping around 5 psi. i have 18 deg until 5200 where i ramp in to 20 deg up top. i shift at 6650 as of right now
Old 06-27-2013, 11:38 AM
  #29
Ferocity02's Avatar
Originally Posted by chevrolet all the way
Also for you guys running low timing and rich to stay conservative need to know that you can very easily go too far and cause much worse damage than a properly tuned engine.
Would running too rich cause detonation? I dropped my AFR from 11.3 to 11.0 to stay safe above 10psi on 91 octane, around 11 deg of timing, and now I'm getting knock retard at WOT around 4500 RPM without any other changes to the tune.
Old 06-27-2013, 12:07 PM
  #30
I have a gauge for that
Atomic's Avatar
Misfire maybe, detonation unlikely.
Quick Reply: Post your Timing and PSI
