Possible to have alot of "lope" FI?
Old Sep 4, 2006 | 10:09 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Well the cam that came in the 6L I got has a toasted lobe so I need to get a new cam anyway. Its hard to believe I wouldnt be leaving any power on teh table by not going with a "turbo" cam.
Old Sep 4, 2006 | 10:11 PM
dirt track racer 81's Avatar
damn trader..good luck with the FI setup..just add a lill nitrous to it..
Old Sep 4, 2006 | 10:13 PM
1slow01Z71's Avatar
I already have a Nitrous Pro Flow plate system to go on the Vic Jr setup
It probably wont get used till it sits on top of the 418 that can handle it.
Old Sep 4, 2006 | 10:15 PM
Stoichiometric's Avatar
I would lean toward a reverse split with a relativly wide lsa regaurdless of what duration or lift you end up going with. The closer lsa cams in a turbo engine blow the exhaust pressure back into the intake during overlap, so that is something to avoid.
Old Sep 4, 2006 | 10:20 PM
1slow01Z71's Avatar
Im not well versed on turbo cams so Ill let someone a bit smarter than me make the decision and see if it works if it doesnt its only 3-4 hours awayf rom being replaced
Old Sep 4, 2006 | 10:27 PM
Sounds good, do you have a 2 piece timing cover? I will be paying close attention to the cam you end up with because I am still sorting out which one I will need
Old Sep 4, 2006 | 10:29 PM
1slow01Z71's Avatar
Nope single piece but pulling the crank pulley isnt a big deal. I have done many cam swaps so Im pretty good at it. Springs are the major PITA and i wont have to touch em. I can have the whole motor out in about 2 hours minus draining coolant, which isnt really something to brag about unfortunately
Old Sep 5, 2006 | 12:31 AM
AintNoHo's Avatar
I agree with it's the overlap that causes the lope. I have a Gen1 with 12lbs boost on a Vortech. With a 232/232 112LSA 8* overlap, there is a slight lope. With a 244/244 112LSA 20* overlap, there's a big time lope and no brake boost. Despite what Desktop Dyno shows, I don't feel a great difference in the two cams. I have heard that with boost you don't get a great deal of benefit from large overlap because the boost blows out the spent exhaust pretty well with a small overlap. It seeems to be the case with these two cams. With the large overlap there's also a decrease in mileage, if that matters. Your cam is about in the middle with 15* overlap.
Old Sep 5, 2006 | 01:05 AM
PappyDan's Avatar
Tribe Shaman
the ls6 551 lift at 117.5 is a good cam.
g2-3 with a litle higher lift at 118.5 is also a good cam.
i don't get looked at to much by law enforcemnet with my stock idol and sound
but everybody around me knows i have something serious under the hood when i turn it loose.
Old Sep 6, 2006 | 03:15 PM
I think you may be able to get away with a 114 LSA which will give you some lope depending on the duration. I think for most applications, lope is going to be minimal, because you don't want the intake and exhaust valve to be open at the same time with a FI set up.
