plugs
Old Nov 16, 2013 | 05:08 PM
cwalker2006's Avatar
Default plugs
Which plugs do yall recommend for my frony mount. I have tr6s now. On 15lbs no meth. But pretty sure I need cokderpkugs or meth. Cruising on the highway today giving it some gas it started cutting out. Or what gap on the tr6s are yall running?
Old Nov 16, 2013 | 05:40 PM
kelsey_canard's Avatar
Are you running pump gas? If so, 15lbs without meth is quite a bit to ask out of pump gas. How much timing are you running? Im sure the majority of people will say to switch to a br7ef and run some meth through it.
Old Nov 16, 2013 | 05:42 PM
TX Tahoe Z71's Avatar
I'm on NGK BR7EF gapped at .035" and run 10psi. No problems.
Old Nov 16, 2013 | 07:24 PM
gamble686's Avatar
I think it's lame when people say you can't do such and such boost without meth or higher octane fuel. Sure meth or better fuel will help make more power, but if timing is dialed in 15lbs can be fine if iats are under control.
Old Nov 16, 2013 | 08:12 PM
Old Nov 17, 2013 | 01:26 PM
Pump gas no meth. I'm ordering a kit on monday. It was the first time its ever done that. I waa fighting the wind the whole time. And it was the last part of the trip when it started acting up
Old Nov 17, 2013 | 01:38 PM
GMCtrk's Avatar
You left out a key piece of info, what's your current gap?
0.028" would be a good place to start.
Old Nov 17, 2013 | 02:58 PM
I wanna say .032 I can't remember. I need to change them anyways. Been in there over a year
Old Nov 17, 2013 | 02:59 PM
Ill regap them and go from there
Old Nov 17, 2013 | 11:01 PM
gamble686's Avatar
Originally Posted by kelsey_canard
Can't? yeah you know what your right it absolutely can't be done no matter what. Not on pump gas. Never. Ricer math at its best.
