please help with radix blower pulley bolt keeps ........
Old Apr 26, 2011 | 12:38 PM
Q8 6.0's Avatar
Default please help with radix blower pulley bolt keeps ........
coming out and the pulley becomes loose and make noise then i have to remove belt push pulley back on then tight the bolt again take it for drive its nice a quiet then 5 minuts later it starts again to make chattering noise again. i tighten the bolt again put therd locker test it and its the same quiet for 5 minutes then the bolt back out loose...and makes the noise again i dont know what to do
dose anyone have trick to make the bolt not back out or is the pulley needs changing????
thanks
Old Apr 26, 2011 | 01:24 PM
bigboy576103's Avatar
wierd maybe i need to go check ours to see if its backed off... this should be interesting to hear the solution on...
Old Apr 26, 2011 | 01:55 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
What brand pulley are you using, and how (what method) are you torquing it on?
Old Apr 26, 2011 | 03:47 PM
Q8 6.0's Avatar
i got the pulley from linginfelter performance two years ago its 2.75" 2 years no problem then few weeks ago it started making noise i ignored the noise and was driving the truck normal then it got worse and noise increace alot, i removed the belt to check, it was the bolt back out very slightly and the pulley play up down now the bolt keeps backing out everytime i torque it.. i did it 3 times now and it wont hold
Old Apr 26, 2011 | 03:50 PM
Q8 6.0's Avatar
i torque it by keeping the belt on it with engine hot the hot belt holds the pulley much better than cold belt
Old Apr 26, 2011 | 07:21 PM
old motorhead's Avatar
Sounds as if you've boogered up the shaft that the pulley bolts to. Unless the pulley is crap, no amount of lock tite and extra torque will fix it now. Time to send it back to the Magnuson folks for repair.
Old Apr 27, 2011 | 10:21 AM
Q8 6.0's Avatar
yes it is the shaft i remove the pulley today there is small oil leak i will remove the nose try to fix it or will order new one
thanks for your help guys
lsxperformance
Apr 20, 2016 12:17 AM
chevysten
Aug 13, 2015 07:36 PM
bigsapper
Jul 28, 2015 12:56 AM
Ammadien
Jul 22, 2015 08:50 PM
