planning a 5.3 turbo build, couple questions
Old May 12, 2014 | 11:53 AM
JCGordon's Avatar
Ok so you guys that are running over 10# on a stock bottom end, did yall do anything to the rings, head studs, or any of that? I just finished a 76mm kit and Im at 8# now. Just wondering what the max boost is on a completely stock 5.3. Its a daily driver as well.
Old May 12, 2014 | 04:12 PM
supercharged680's Avatar
i would just do head studs, LS9 gaskets and NGK BR7EF plugs. i would leave the rings as they are up to around 17 psi.
Old May 13, 2014 | 08:04 AM
TURBHOE's Avatar
Save the money you would use to build the 5.3 and put it in the trans!
Stock ring gaps have worked but they are tiny so if the piston get warm from bad tuning the top ring will too. When it butts that's when you lose the top ring land. If you can find one I suggest getting an old ls1 steam vent set up. That allows the steam that forms on the back side of the engine to escape. Steam won't cool and cause 7/8 to swell, if this happens you get the wonderful number 7 to go by by.
Old May 22, 2014 | 10:47 PM
N20addiction's Avatar
Okay so what ill do then is pull the 4.8 and fix some leaks and freshen it up and do ls9 gaskets, some head studs. What intake? Ls7 maybe? And ill leave the stock cam and heads for now, im saving for the kit and other bs parts, ill start a build thread once ive got some parts rolling in
Old May 23, 2014 | 12:20 PM
Funkster's Avatar
12 Second Club
The stock intake is fine and works for a better powerband for these pigs. Use the money for a custom cam, and better timing chain.
The_W
Oct 28, 2015 09:00 PM
Noah Burns
Sep 7, 2015 05:50 PM
USMCvet0311
Aug 14, 2015 10:28 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Cowboy17
Jul 9, 2015 06:18 PM
