placement of 02s
Old Aug 9, 2007 | 11:27 PM
Quik's Avatar
5 year bitches!
Default placement of 02s
ive been looking at various setups but none are consistant IMHO on where the 02s are placed. ive seen some tht are right after the manifold/log which is before the turbo/turbos. then i seen other setups where the 02s are after the turbos in the downpipes......
ok which is the proper location?
and for another question where should the wideband be placed
Old Aug 9, 2007 | 11:38 PM
kbracing96's Avatar
On my setup, the driver side it in the cross over about in the stock location, the passenger side is in the log right before the turbo and the WB is in the down pipe 8" from the turbo. Seems to be working great.
Old Aug 9, 2007 | 11:41 PM
TrickTurbo's Avatar
Truck Sponsor
WB put in the downpipe. A good wideband can be installed into any part of the exhaust. But you must stay 24" from the tail pipes end. We put ours in the DP anywhere easy to get too.
The other O2s just depends. One single turbo applications before or after the turbo will have little effect. We put the drivers side in the stock location, and let the customer deside where he wants his passenger side one.
Rick
Old Aug 10, 2007 | 12:18 AM
Quik's Avatar
5 year bitches!
so on a twin setup where should the narrow bands go?
and put wideband in the driverside down pipe?
also is anyone using a EGT and where are they installing them
Old Aug 10, 2007 | 12:42 AM
camcojb's Avatar
I've been told by people I trust that you do not want the O2's before the turbo, as the exhaust pressure skews the a/f readings. Even the good widebands are not calibrated with exhaust pressure. Do so at your own risk.
Jody
Old Aug 10, 2007 | 12:51 AM
Quik's Avatar
5 year bitches!
Jody
now how would the exhaust pressue mess up the narrowbands if the yare before the turbos? that would be equilvant to how a stock motor is
Old Aug 10, 2007 | 09:33 AM
camcojb's Avatar
exhaust pressure. You will have several pounds of it in front of a turbo, you have virtually none in a normal naturally aspirated engine, unless the converter or muffler is plugged. The O2's readings change as pressure is introduced, so they will not be accurate. There have been several threads about this on LS1Tech.
Jody
Old Aug 10, 2007 | 09:46 AM
vanillagorilla's Avatar
Mine narrow bands are both before the turbo, basically in the stock location still. My WB is after the turbo, like 12" or so. Most run a SD OL tune and tune off the WB only, so who gives a crap what the narrow bands read.
FWIW, Innovate's instructions specifically say NOT to but the wideband before the turbo.
Old Aug 10, 2007 | 09:50 AM
kbracing96's Avatar
Narrow band o2's are not used when your boosting, you will be in open loop. With mine and custom OS3 from EFILive, I'm hardly ever in closed loop anyway. I'm ether running a bit lean in lean cruise mode, or rich in "boost" mode. I only have a small window where I'm actually running in closed loop 14.7 with the stock narrow 02's.
I don't think it would make a diff in which side you put the WB, maybe in the drivers, just you you would base your tune off of the #7, but you can't control fueling from side to side anyway. One side gona be the same as the other unless for some reason you have a fueling problem, like a bad injector or something.
Old Aug 10, 2007 | 09:59 AM
camcojb's Avatar
Yep, stock O2's can remain where they are, as they don't affect your wot tuning. You should be using a wideband for WOT tuning (as you plan to) and it should be after the turbo(s).
Jody
