piston rings for FI LSx builds...
Old Dec 16, 2007 | 10:15 AM
Superado's Avatar
11 Second Truck Club
Default piston rings for FI LSx builds...
update: got the rings...question now is in reference to gap...go to page 2...
preferably, based on personal experiences...please post your preferred brand of rings for boosted applications...
also, any info you have found in researching different rings for boost is welcome as well...
I have a forged LS1 build in the staging lanes
thanks in advance!
no poll this time...just for you and Jerry
Old Dec 16, 2007 | 10:32 AM
supersub's Avatar
Childs + akerly Extreme nitrous 1/16 1/16 3/16 4.125's Boosted application! See sig
Old Dec 16, 2007 | 10:37 AM
Stoichiometric's Avatar
I went with a set of Ackerly and Childs Hellfire rings for my 408 based on reccomendation from Richard at WCCH and Rex.
I had already bought a set of Total Seal gapless rings that I planned to use to help keep oil consumption down on my 408. When I pulled the gapless top ring out of the box I could see that a good portion of the ring was missing to accomodate the sealing ring that sits on the top ring. It is hard to explain, but basically I had a 1/16 ring that was more like 1/32 on the top. I could see problems with this in a high boost engine. I'll stick to the standard ring sets from now on.
Old Dec 16, 2007 | 10:46 AM
Superado's Avatar
I have heard the same about not using the gapless, however, the Total Seal AP rings are highly recommended...
Recently found out that Hastings Mfg. (Hastings Piston Rings) makes WiseCo's rings as well as Total Seal's...whodathunkit???
I have been told that the HellFire rings were more suited for a "track only" motor...and not suited very well for a DD...
Old Dec 16, 2007 | 10:53 AM
Superado's Avatar
supersub...any pics of that suburban?
sounds like a sweet build...a S/C SS Suburban
Old Dec 16, 2007 | 10:57 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I let diamond "custom match" a set of their rings to my custom slugs. I don't really know what that means, except that I'm running diamond rings
Old Dec 16, 2007 | 11:01 AM
supersub's Avatar
Old Dec 16, 2007 | 11:12 AM
Superado's Avatar
My pistons are Diamond as well...I thought about going with their Pro Select rings for these pistons...
I bought a used, balanced rotating assy...current rings are Total Seal AP's...Diamond slugs and Howard rods...stock crank
supersub...thanks for the pic...that is one sweet sub...
sorry for hijacking my own thread
now back to the rings...
Old Dec 16, 2007 | 11:16 AM
Wilde Racing's Avatar
How do I change this text
I was told the same thing the ring tends to wear out the bore more and has a harder time "Seating"
I would go with GFX rings. But I do not have any experience with any......
Old Dec 16, 2007 | 11:19 AM
supersub's Avatar
I was told they just need to be broke in properly to work,use an oil with lots of zinc and phosporous for the break in to seat the rings then you are golden.
