piston rings for FI LSx builds...
the rings on the pistons I bought seem to measure 1.5mm, 1.5mm, 3.0mm
finding an off the shelf 3.905 set in these thicknesses are between slim and none...
I did find a set today...WiseCo...manufactured by Hastings...
I believe that Lunati carries the same set...same part number...
http://www.wiseco.com/PDFs/Catalogs/...ompressors.pdf
the low tension oil ring is the only thing I question...
TurboBerserker...what are the specs on your Diamond Pro Selects
Mfr Part#: 39050GK
Description: High tech piston rings. These GK piston rings from Wiseco offer a ductile iroln plasma moly coated top ring. The second ring is a taper faced ferrox coated cast iron style. The oil rings are a 3-piece mini-flex vent design. These piston rings are a perfect replacement for stock to high performance engines.
ended up getting a set of Mahle 3910MS-5 standard tension, file fit rings...
what end gaps are you guys running for FI? I should be at 14 - 15 #'s of boost...
I thought it should be about .0195 - .020 top ring and .0215 - .022 second ring, but I just called Diamond for their recommendedation for their pistons and they said
.022 - .023 top ring and .024 - .025 second ring...for that boost level...
Jason...you mean your gap is the same as what Diamond recommended?
...how's the truck?
anyone else familar with what gap they used?
...how's the truck?
