Pics of who's running kb racing turbo kit
Old May 5, 2013 | 07:27 AM
  #111
farmallcub's Avatar
Don't know what IAT is....
But, the BOV has a stronger spring in it than the wastegate and I have the gate tied to the manifold for some control and it has a 7psi spring.
The truck is an automatic so I don't really have the throttle shutting on a shift.
I am also not really running it hard except for the occasional playing around.
The BOV and connection came with the kit so it had to go on or get a different elbow.
Also, I was learning as I built it so I didn't really know much, still don't know much more!
With that said, the BOV has not yet BO'ft that I can tell.
As far as the tune goes, running a little rich. I had the engine light come on and checked the code, rich right and left, plus I can smell it.
No problems other than when I blew the coupling off a couple times at first.
I just bought the AutoCal from Black Bear so we can do some email tuning. He'll give me as many tunes as I need. I want to develop a tune, if possible, to make it fuel efficient like the Ford ecoboost.
I may even have to swap out the turbo to get one that spools up at a lower rpm, don't know yet.
Still learning and could use any help you guys can offer
Old May 5, 2013 | 09:15 AM
  #112
Gadgetized's Avatar
IAT is Intake Air Temperature. They are suggesting that you might not be using the MAF to control the fuel according to airflow, and only have it there to tell the IAT. The concern is that if you are using the MAF, air is passing the MAF telling the computer that it is entering your engine, then when your BOV opens up and it does not enter the engine. The computer can not tell that it never made it to the engine and therefore adds fuel as if the engine is needing it.
Old May 5, 2013 | 10:45 AM
  #113
Atomic's Avatar
I have a gauge for that
Do you have the reference line connected on the BOV to the intake manifold?
Old Jun 15, 2013 | 03:57 PM
  #114
darnie's Avatar
Old thread, but i was wondering if anyone had any pics of the inner cooler piping running from behind the grill. I monuted mine up there with the inlet/outlet towards the top.
Old Jun 16, 2013 | 03:00 PM
  #115
Alpinestar's Avatar
I probably already posted somewhere in this thread but here it is again. I think the IC's dimensions are 31x12.5x3 with 3" tubing from cxracing. With the in/outlets at the top, the easiest routing is to go right beside the radiator (if you still have the factory 28"). Send me a message if you have any other questions about the routing.
I recently switched to the 34" radiator and had to redo everything. Had to flip the IC with the in/outlets at the bottom. Here are a few pictures if you give af
Old Jun 16, 2013 | 07:40 PM
  #116
darnie's Avatar
Ya man, appricate it. I got the piping from the turbo to the IC. Just gotta get from the IC to the intake figured out. Also what turbo u running
Old Jun 16, 2013 | 07:49 PM
  #117
Alpinestar's Avatar
Just a 70mm master power
Old Aug 13, 2013 | 01:06 AM
  #118
Big Reade's Avatar
I've got the CX Racing 3" in/out setup as well, trying to figure out where to mount the ic right now.
Old Aug 13, 2013 | 01:08 AM
  #119
Big Reade's Avatar
Are your cold pipes welded together? I was just wondering how the CX pipes were for welding.
Old Aug 13, 2013 | 01:53 PM
  #120
shifty89's Avatar
They weld fine, just keep it clean.
