Phenolic spacer for Magnuson
Hello all, just recently started putting together a little mp112 for my wife's car and had to split the case apart to fix a few things. In the mean time I found someone selling some leftover RDS stock. Picked one up so cheap I figured why not.
Couple questions... I saw a couple threada where people used RTV on both sides of the spacer when reinstalling, is this necessary? It comes with a groove cut out and a factory Magnuson rope seal and O rings. Second, are people still running these with decent results? Any insight is appreciated
does it or should I sandwich a little RTV in between both layers?
I found that listing as well and I am on the fence about buying it. Doesn't these spacers require injector spacers to be used as well?
Also, would the spacer between the heads and lower tub work just as well to limit heat transfer?
Ya I ordered 1/2" injector spacers from ICT billet. Should be just about right. Also I figured this type would be better as it's a barrier right before the IC.. but who knows. I figured it was cheap enough and couldn't hurt. I honestly figured they'd all be scooped up by now.
