PCV setup and Vacuum source setup
Old Jul 21, 2015 | 12:39 PM
George C....'s Avatar
Formerly ScreamingL
Who told you to not run vented covers?
Old Jul 21, 2015 | 12:45 PM
mhorn0817's Avatar
tuner
Old Jul 21, 2015 | 01:17 PM
Formerly ScreamingL
Go figure........
Old Jul 21, 2015 | 01:23 PM
mhorn0817's Avatar
tuner via internet and datalogs. just want the truck running right and good while i save up for stall, cam, heads, meth. then ill take it to get dyno tuned and be done for a while
Old Jul 21, 2015 | 01:37 PM
Atomic's Avatar
I have a gauge for that
The truth is you dont have a lot of choice in how to plumb the covers. You need to exhaust blowby gases, period. You do have choice in how you tune it. I would suggest elimanting the MAF and go SD so you wont have to deal with air leakages.
Old Jul 21, 2015 | 02:46 PM
mhorn0817's Avatar
ok, how do i go about eliminating maf and going sd?
Old Jul 21, 2015 | 02:53 PM
Formerly ScreamingL
Search it's been detailed for over a decade
Old Jul 21, 2015 | 03:07 PM
Atomic's Avatar
Unplug and remove maf. Use the 2 wires from the MAF connector to install a separate IAT sensor somewhere in the intake track.
Old Jul 8, 2017 | 01:54 AM
juanioz28's Avatar
Originally Posted by mhorn0817
runs decent how it is now, it wont boost past 5psi. im pretty sure i have the 12lb spring in the wastegate, i will double check though.
idles at low 15s AFR instead of low 14s, and goes rich at WOT
not sure which its tuned on to be honest. theres a maf and a map, not sure which one is being used.
no i didnt read it on the interenet, my tuner told me that information. still waitng to hear back with his suggestions as to what and how to run it.
2 or 3 bar map sensor
lucas287
31
Jan 12, 2021 06:18 AM
simman22
Jan 21, 2017 10:27 PM
kmcn47
Sep 17, 2015 01:12 AM
cousblake11
Sep 9, 2015 06:52 PM
