pcv check valve
Old Aug 29, 2008 | 08:37 PM
phasemaster1's Avatar
Default pcv check valve
Sorry guys I have a brain fart...Im trying to retain the pcv system but can remember which way the check valve flow is. Into the manifold or the valve cover?Did the same set up Ranwalk has with the oil separator on the drivers side. Thanks
Jaime
Old Aug 29, 2008 | 09:14 PM
1BADAZZSS's Avatar
Jaime
You want the check valve to let the crank case vent back into the manifold but not let the manifold push air (boost) into the crank case. Simple way, which ever side you cannot force air through with your mouth you want that side to go to the intake manifold. Do I have this right guys??? Is this what you are asking Jamie And when you say oil separator you talking about a oil catch can right? They have so many different names for those things. I hope this helps.
Old Aug 30, 2008 | 07:27 AM
1BADAZZSS thats exactly what Im talking about thank you.
Stainless Works
Apr 10, 2016 04:34 PM
Fast86z
Aug 23, 2015 12:35 AM
TAPyvehc93
Aug 21, 2015 05:19 AM
jroctpb
Aug 11, 2015 03:52 PM
Stainless Works
Aug 4, 2015 12:56 PM
